zabbix configuration file fail 1.8.7
  • bazzieb
    • Sep 2011
    Hi There
    I have installed zabbix 1.8.7 on Ubuntu 10.04 but when i run the initial setup i get the following error:
    Configuration file: fail
    I have saved the config file and placed it under the folder. I tried giving permissions to the folder as well.
    I would appreciate any more advise
    Kind Regards
    bazzieb
  • bazzieb
    • Sep 2011
    found error
    I found my mistake, copied the conf file to the wrong folder
    • tienpt
      • Sep 2012
      • 29
      Hi Bazzied, can you help me? how did you do?
