hi iam using 1.1beta8 but there is not in configuration media, where email will be sent, but i don't have mailserver on the same machine on localhost but on another, its possible to use another smtp? thank for help
I use the lightweight nbsmtp client that is easy to setup and can even run inside a chroot jail without any problems. You can find info in the following thread (it talks about authenticated smtp but will work just as well for other smtp servers)
