Config template items and triggers hangs
  • LenR
    • Sep 2009
    • 1011
    I was adding some items to our linux template and the web interface has stopped responding at times. For example, I can go to config triggers, but when I try to go to the 2nd screen, it hangs.
    Zabbix version 1.8.10 on RHEL 5.8, mysql 5.0.95, everything is on one server.
    Thanks.
  • LenR
    • Sep 2009
    • 1011
    I think the last trigger I added to the template must be the cause. It is disabled, if I "hide disabled triggers", navigation works. I can navigate 3 of the 4 item screens for the template, just not the one that links to the bad trigger.
    Any ideas on how to fix this?
    • LenR
      • Sep 2009
      • 1011
      I restored the database to the prior night's backup and it's OK now.
      • ghoz
        • May 2011
        • 204
        I would be interesting to find the root cause and file a bug to the tracker...
        a trigger is not supposed to be able to hang the frontend :-)
        • LenR
          • Sep 2009
          • 1011
          My guess is it's something bad in the database, but I don't know how to debug it.
          • LenR
            • Sep 2009
            • 1011
            I think this is the symptom of the problem
            PHP Fatal error: Maximum execution time of 600 seconds exceeded in /var/www/html/zabbix-1.8.10/api/classes/class.ctrigger.php on line 555,
