I've been validating all available documentation but did not yet find the issue at hand. I used configuration files from sources.
Unless i'm mistaken i've ran into multiple issue with Zabbix 2.0.1 compiled from source. Which worked fine for 1.8.5
- Discovery is not working for combined discoveries of HTTP, HTTPS, SNMPv2, ICMP ping
- SNMP queries run fine from the commandline ( snmpwalk, snmpget tested )
- A tcpdump monitor shows the discovery is effectively not running, the cron is not running ? Commands are available with suid bit set on fping, ping etc
There is no specific log indicating any issue at this time, unless i've missed out on this.
Regards,
JL
Regards,
JL
