Zabbix server is not running:
  • jsantiago
    • May 2012
    • 39
    Hi experts,
    I was finally able to complete the installation of Zabbix 2.0.2 on CentOS.
    However, "Zabbix server is not running: the information displayed may not be current." message is on the dashboard.
    I did the following:
    1. Changes the SELinux to permissive (learned from zabbix forum).
    2. Checked the config files if correct password is used on the database, which is correct (learned from zabbix forum)
    Still have the same issue after doing the steps above.
    Hope to hear from you soon.
    Thank you.
  • luis_josue
    • Oct 2012
    • 13
    oye amigo....encontraste solucion??? yo estoy igual como practicante
    y pues estoy con que no corre ni nada....si encontraste solucion me
    mandas a mi correo: [email protected] te agradece
    de antemano.
    • jsantiago
      • May 2012
      • 39
      Hi Luis,
      Sadly, we have the same problem I guess. Once I have the solution, I'll post it here. Good luck.
      • badener
        • Sep 2009
        • 42
        zabbix.conf.php
        the message shown does not refer to the database but to the actual server. Check in zabbix.conf.php
        $ZBX_SERVER and
        $ZBX_SERVER_PORT
        Make sure that port on the given server is your Zabbix Server and can be reached from the frontend server.
        Good luck
        • jsantiago
          • May 2012
          • 39
          Thank you for the reply badener.
          I will check on the config file. Thing is, it's an all in one box. That ! box is the database server, frontend server and the zabbix server itself.
          • badener
            • Sep 2009
            • 42
            having everything on one box shouldn't be a problem - that's how I started as well; once you found those parameters su to the user running your web server and try telnet $ZBX_SERVER $ZBX_SERVER_PORT
            if the server is up and running and listening on the port the connection should succeed - if not you could check the local firewall (if you use one)
            • jsantiago
              • May 2012
              • 39
              zabbix_server.conf
              Hi badener,
              I've heavily based my installation on this manual: http://www.zabbix.com/wiki/howto/ins.../centosinstall
              with a little tweaks due to zabbix version.
              I've actually checked zabbix_server.conf files and as far as the database server connection and usernames are correct. In addition, I've also checked the zabbix.conf.php which is found on the /var/www/html/zabbix/conf database profiles are also the same as with the previous file.
              I've also had the chance to run the latest zabbix appliance 2.0.2 that run on opensuse. Checked on the zabbix_server.conf and it is pretty much the same as what I have on the installation. I also tried looking for the zabbix.conf.php on the appliance but I couldn't find it.
              Sadly, after doing all of these and redoing it again, I still have the Zabbix server is not running: the information displayed may not be current.
              • luis_josue
                • Oct 2012
                • 13
                Hola, pues a mi se me arreglo eso, descarga ""yum extender" y actualiza el servicio, sale algo asi como zabbix_server_mysql el cual es un proceso que actua por los dos....o algo asi!!
                • jsantiago
                  • May 2012
                  • 39
                  Hi Luis,
                  I've tried installing the yum extender : yum install yumex, restarted apache and even tried restarting the machine still same error is encountered.
                  Still trying to figure this out though.
                  Thank you.
                  • herta
                    • Sep 2011
                    • 101
                    anything useful in the log file?
                    If you don't know where it's at, try
                    "grep -i log /usr/local/etc/zabbix_server.conf"
                    Kind regards,
                    Herta
                    • Riscaa
                      • Nov 2006
                      This is occuring with me as well on a rhel5 box.
                      • Riscaa
                        • Nov 2006
                        heh, zabbix_server logs filled with
                        30071:20121011:004850.173 [Z3001] connection to database 'zabbix' failed: [1045] Access denied for user 'zabbix'@'localhost' (using password: NO)
                        • Riscaa
                          • Nov 2006
                          had to edit /etc/zabbix/zabbix_server.conf and edit this section
                          ### Option: DBPassword
                          # Database password. Ignored for SQLite.
                          # Comment this line if no password is used.
                          # Mandatory: no
                          # Default:
                          DBPassword=yourdbpasswordhere!
                          • jsantiago
                            • May 2012
                            • 39
                            zabbix_server.log
                            Hi Riscaa,
                            Thank you for your reply. You have lead me to the right path of troubleshooting this. I've checked on the zabbix_server.log and found to errors on it:
                            1. [2002] Can't connect to local MySQL server through socket '/var/lib/mysql/mysql.sock
                            2. [1045] Access denied for user 'root'@'localhost' (using password: NO)
                            With error #2, which username and password should it be when connecting to the Zabbix Database? Zabbix (created) or the Root user?
                            I've actually tried both zabbix and root user and made sure that /etc/zabbix_server.conf and /var/www/html/zabbix/conf/zabbix.conf.php are the same but to no success.
                            • Riscaa
                              • Nov 2006
                              #15
                              If it cant connect it almost sounds like the mysql server may not be running? I'd check that.
