Zabbix server is not running:
  • jsantiago
    • May 2012
    • 39
    #16
    Riscaa,
    Somehow after several change in the config still I can't get the passwords to sync. I've decided to re-install zabbix and start from scratch.
    It seems I need to brush up my MySQL skills, I was able to complete the installation with no error and started zabbix frontend with no error with a help from a Database GUI.
    From the the installation instruction: http://www.zabbix.com/wiki/howto/ins.../centosinstall
    I may have done this incorrectly:
    mysql> grant all privileges on zabbix.* to 'zabbix'@'localhost' identified by 'set-password-here';
    mysql> quit;
    (Granting access to a user on zabbix database) this step really frustrates me.
    But nonetheless its, working fine now. Thank you.
    • jsantiago
      • May 2012
      • 39
      #17
      This is really strange.
      I've started my Zabbix frontend successfully or so I though it was and it seems to be working well until I rechecked the server logs.
      It was full of:
      [Z3001] connection to database 'zabbix' failed failed: [1045] Access denied for user 'root'@'localhost' (using password: NO)
      I've tried matching the passwords on both /etc/zabbix/zabbix_server.conf and /var/www/html/zabbix/conf/zabbix.conf.php both are identical.
      I've made sure that the mysql password that I'm using is also the same, i even used navicat to make sure i have it correctly using the GUI.
      Are there any other key points where I can recheck and verify that I have the correct database password?
      • herta
        • Sep 2011
        • 101
        #18
        a few things to verify
        - as previously suggested by Riscaa, is mysql up and runnning?
        (ps auxw | grep mysql)
        - can you log into the database using the username and password in the config file?
        ("mysql -u zabbix -p zabbix" - when prompted, enter the password in the zabbix_server.conf file)
        • jsantiago
          • May 2012
          • 39
          #19
          verified
          Thanks for the reply herta. I never realized that.
          I think it's ok now. I'm totally a noob on mysql, but I'm learning it bit-by-bit.
          Thank you for your help.
          • tiller
            • Dec 2011
            Zabbix Server Not Running
            I am having the same issue, but I don't get the error all the time. It seems like every other refresh of the dashboard page the error shows up then goes away. The only messages in the zabbix_server.log is the housekeeper messages. I just upgraded from version 8.5 to 2.0.03.
            Any help would be appreciated.
            • tob
              • Dec 2008
              • 25
              #21
              Under CentOS you can safely assume SELinux is in your way.
              One could disable SELinux totally with: # setenforce 0
              But, needless to say is not the most secure option ;-)
              To permit what zabbix frontend actually wants:
              # setsebool -P httpd_can_network_connect=true
              • jterrill
                • Feb 2013
                Thanks tob!
                • rugwiza
                  • Jan 2013
                  • 16
                  #23
                  zabbix not running
                  Hello, please if we can find the right zabbix expert,
                  please help.
                  I have the same issue: zabbix is not running: the information displayed may not be current.
                  on centos, tried to figure out the cause
                  for almost one month with no success.
                  please help
                  please help
                  • herta
                    • Sep 2011
                    • 101
                    #24
                    more info required
                    rugwiza,
                    - what is your config (OS, db, zabbix version)
                    - how much of what is posted here have you checked? (database up and running, accessible using the password in the config file, log files...)
                    • rugwiza
                      • Jan 2013
                      • 16
                      #25
                      zabbix not running
                      Hello Herta,
                      The OS is centos 6.0
                      mysql is up and running:
                      mysqladmin -u root -p status
                      Enter password:
                      Uptime: 1228988 Threads: 17 Questions: 5304600 Slow queries: 0 Opens: 1464 Flush tables: 1 Open tables: 64 Queries per second avg: 4.316
                      when i checks logs in /var/log/zabbix/zabbix_agentd; the result is:
                      6500:20130303:001040.467 No active checks on server: host [Zabbix server] not monitored
                      6500:20130303:001240.487 No active checks on server: host [Zabbix server] not monitored
                      6500:20130303:001440.509 No active checks on server: host [Zabbix server] not monitored
                      6500:20130303:001640.534 No active checks on server: host [Zabbix server] not monitored
                      6500:20130303:001840.554 No active checks on server: host [Zabbix server] not monitored
                      6500:20130303:002040.575 No active checks on server: host [Zabbix server] not monitored
                      6500:20130303:002240.604 No active checks on server: host [Zabbix server] not monitored
                      when i checks logs in /var/log/zabbix/zabbix_server; the result is:
                      22579:20130301:135157.647 executing housekeeper
                      22579:20130301:135157.681 housekeeper deleted: 0 records from history and trends, 0 records of deleted items, 0 events, 0 alerts, 0 sessions
                      22573:20130301:135238.359 cannot send list of active checks to [127.0.0.1]: host [Zabbix server] not monitored
                      22573:20130301:135438.387 cannot send list of active checks to [127.0.0.1]: host [Zabbix server] not monitored
                      22573:20130301:135638.407 cannot send list of active checks to [127.0.0.1]: host [Zabbix server] not monitored
                      22573:20130301:135838.435 cannot send list of active checks to [127.0.0.1]: host [Zabbix server] not monitored
                      22573:20130301:140038.461 cannot send list of active checks to [127.0.0.1]: host [Zabbix server] not monitored
                      22573:20130301:140238.486 cannot send list of active checks to [127.0.0.1]: host [Zabbix server] not monitored
                      22573:20130301:140438.513 cannot send list of active checks to [127.0.0.1]: host [Zabbix server] not monitored
                      22573:20130301:140638.541 cannot send list of active checks to [127.0.0.1]: host [Zabbix server] not monitored
                      22573:20130301:140838.564 cannot send list of active checks to [127.0.0.1]: host [Zabbix server] not monitored
                      22573:20130301:141038.582 cannot send list of active checks to [127.0.0.1]: host [Zabbix server] not monitored
                      22573:20130301:141238.604 cannot send list of active checks to [127.0.0.1]: host [Zabbix server] not monitored
                      22573:20130301:141438.627 cannot send list of active checks to [127.0.0.1]: host [Zabbix server] not monitored
                      22573:20130301:141638.647 cannot send list of active checks to [127.0.0.1]: host [Zabbix server] not monitored
                      22573:20130301:141838.670 cannot send list of active checks to [127.0.0.1]: host [Zabbix server] not monitored
                      22573:20130301:142038.694 cannot send list of active checks to [127.0.0.1]: host [Zabbix server] not monitored
                      22573:20130301:142238.721 cannot send list of active checks to [127.0.0.1]: host [Zabbix server] not monitored
                      22573:20130301:142438.747 cannot send list of active checks to [127.0.0.1]: host [Zabbix server] not monitored
                      22573:20130301:142638.769 cannot send list of active checks to [127.0.0.1]: host [Zabbix server] not monitored
                      22573:20130301:142838.790 cannot send list of active checks to [127.0.0.1]: host [Zabbix server] not monitored
                      22573:20130301:143038.810 cannot send list of active checks to [127.0.0.1]: host [Zabbix server] not monitored
                      22573:20130301:143238.828 cannot send list of active checks to [127.0.0.1]: host [Zabbix server] not monitored
                      22573:20130301:143438.849 cannot send list of active checks to [127.0.0.1]: host [Zabbix server] not monitored
                      22573:20130301:143638.872 cannot send list of active checks to [127.0.0.1]: host [Zabbix server] not monitored
                      22573:20130301:143838.900 cannot send list of active checks to [127.0.0.1]: host [Zabbix server] not monitored
                      22573:20130301:144038.924 cannot send list of active checks to [127.0.0.1]: host [Zabbix server] not monitored
                      22573:20130301:144238.947 cannot send list of active checks to [127.0.0.1]: host [Zabbix server] not monitored
                      22573:20130301:144438.972 cannot send list of active checks to [127.0.0.1]: host [Zabbix server] not monitored
                      22573:20130301:144638.994 cannot send list of active checks to [127.0.0.1]: host [Zabbix server] not monitored
                      22573:20130301:144838.017 cannot send list of active checks to [127.0.0.1]: host [Zabbix server] not monitored
                      • rugwiza
                        • Jan 2013
                        • 16
                        #26
                        zabbix not running
                        the /etc/zabbix/zabbix_agentd.conf conf file looks like this:
                        # This is a config file for the Zabbix agent daemon (Unix)
                        # To get more information about Zabbix, visit http://www.zabbix.com
                        ### Option: PidFile
                        # Name of PID file.
                        # Mandatory: no
                        # Default:
                        # PidFile=/tmp/zabbix_agentd.pid
                        PidFile=/var/run/zabbix/zabbix_agentd.pid
                        ### Option: LogFile
                        # Name of log file.
                        # If not set, syslog is used.
                        # Mandatory: no
                        # Default:
                        # LogFile=
                        LogFile=/var/log/zabbix/zabbix_agentd.log
                        ### Option: LogFileSize
                        # Maximum size of log file in MB.
                        # 0 - disable automatic log rotation.
                        # Mandatory: no
                        # Range: 0-1024
                        # Default:
                        # LogFileSize=1
                        LogFileSize=0
                        ### Option: DebugLevel
                        # Specifies debug level
                        # 0 - no debug
                        # 1 - critical information
                        # 2 - error information
                        # 3 - warnings
                        # 4 - for debugging (produces lots of information)
                        "zabbix_agentd.conf" 243L, 5807C
                        • rugwiza
                          • Jan 2013
                          • 16
                          #27
                          zabbix not running
                          the /etc/zabbix/zabbix_agentd.conf looks like this:
                          ### Option: TmpDir
                          # Temporary directory.
                          # Mandatory: no
                          # Default:
                          # TmpDir=/tmp
                          ### Option: Include
                          # You may include individual files or all files in a directory in the configuration file.
                          # Installing Zabbix will create include directory in /usr/local/etc, unless modified during the compile time.
                          # Mandatory: no
                          # Default:
                          # Include=
                          # Include=/usr/local/etc/zabbix_server.general.conf
                          # Include=/usr/local/etc/zabbix_server.conf.d/
                          ### Option: StartProxyPollers
                          # Number of pre-forked instances of pollers for passive proxies.
                          # Mandatory: no
                          # Range: 0-250
                          # Default:
                          # StartProxyPollers=1
                          ### Option: ProxyConfigFrequency
                          # How often Zabbix Server sends configuration data to a Zabbix Proxy in seconds.
                          # This parameter is used only for proxies in the passive mode.
                          # Mandatory: no
                          # Range: 1-3600*24*7
                          # Default:
                          # ProxyConfigFrequency=3600
                          ### Option: ProxyDataFrequency
                          # How often Zabbix Server requests history data from a Zabbix Proxy in seconds.
                          # Mandatory: no
                          # Range: 1-3600
                          # Default:
                          • rugwiza
                            • Jan 2013
                            • 16
                            #28
                            sorrry this is the full file content of zabix_agentd.conf
                            ### Option: PidFile
                            # Name of PID file.
                            # Mandatory: no
                            # Default:
                            ### Option: LogFile
                            # Name of log file.
                            # Mandatory: no
                            # Default:
                            # LogFile=
                            # Mandatory: no
                            # Range: 0-1024
                            # Default:
                            # LogFileSize=1
                            LogFileSize=0
                            # 0 - no debug
                            # 3 - warnings
                            # Mandatory: no
                            # Range: 0-4
                            # Default:
                            # DebugLevel=3
                            ### Option: SourceIP
                            # Source IP address for outgoing connections.
                            # Mandatory: no
                            # Default:
                            # SourceIP=
                            ### Option: EnableRemoteCommands
                            # Whether remote commands from Zabbix server are allowed.
                            # 0 - not allowed
                            # 1 - allowed
                            # Mandatory: no
                            # Default:
                            # EnableRemoteCommands=0
                            ### Option: LogRemoteCommands
                            # Enable logging of executed shell commands as warnings.
                            # 0 - disabled
                            # 1 - enabled
                            # Mandatory: no
                            # Default:
                            # LogRemoteCommands=0
                            ##### Passive checks related
                            ### Option: Server
                            # List of comma delimited IP addresses (or hostnames) of Zabbix servers.
                            # Incoming connections will be accepted only from the hosts listed here.
                            # No spaces allowed.
                            # If IPv6 support is enabled then '127.0.0.1', '::127.0.0.1', '::ffff:127.0.0.1' are treated equally.
                            # Mandatory: no
                            # Default:
                            # Server=
                            Server=127.0.0.1
                            ### Option: ListenPort
                            # Agent will listen on this port for connections from the server.
                            # Mandatory: no
                            # Range: 1024-32767
                            # Default:
                            # ListenPort=10050
                            ### Option: ListenIP
                            # List of comma delimited IP addresses that the agent should listen on.
                            # First IP address is sent to Zabbix server if connecting to it to retrieve list of active checks.
                            # Mandatory: no
                            # Default:
                            # ListenIP=0.0.0.0
                            ### Option: StartAgents
                            # Number of pre-forked instances of zabbix_agentd that process passive checks.
                            # If set to 0, disables passive checks and the agent will not listen on any TCP port.
                            # Mandatory: no
                            # Range: 0-100
                            # Default:
                            # StartAgents=3
                            ##### Active checks related
                            ### Option: ServerActive
                            # List of comma delimited IPort (or hostnameort) pairs of Zabbix servers for active checks.
                            # If port is not specified, default port is used.
                            # IPv6 addresses must be enclosed in square brackets if port for that host is specified.
                            # If port is not specified, square brackets for IPv6 addresses are optional.
                            # If this parameter is not specified, active checks are disabled.
                            # Example: ServerActive=127.0.0.1:20051,zabbix.domain,[::1]:30051,::1,[12fc::1]
                            # Mandatory: no
                            # Default:
                            # ServerActive=
                            ### Option: Hostname
                            # Unique, case sensitive hostname.
                            # Required for active checks and must match hostname as configured on the server.
                            # Value is acquired from HostnameItem if undefined.
                            # Mandatory: no
                            # Default:
                            # Hostname=
                            Hostname=Zabbix
                            ### Option: HostnameItem
                            # Item used for generating Hostname if it is undefined.
                            # Ignored if Hostname is defined.
                            # Mandatory: no
                            # Default:
                            # HostnameItem=system.hostname
                            ### Option: RefreshActiveChecks
                            # How often list of active checks is refreshed, in seconds.
                            # Mandatory: no
                            # Range: 60-3600
                            # Default:
                            # RefreshActiveChecks=120
                            ### Option: BufferSend
                            # Do not keep data longer than N seconds in buffer.
                            # Mandatory: no
                            # Range: 1-3600
                            # Default:
                            # BufferSend=5
                            ### Option: BufferSize
                            # Maximum number of values in a memory buffer. The agent will send
                            # all collected data to Zabbix Server or Proxy if the buffer is full.
                            # Mandatory: no
                            # Range: 2-65535
                            # Default:
                            # BufferSize=100
                            ### Option: MaxLinesPerSecond
                            # Maximum number of new lines the agent will send per second to Zabbix Server
                            # or Proxy processing 'log' and 'logrt' active checks.
                            # The provided value will be overridden by the parameter 'maxlines',
                            # provided in 'log' or 'logrt' item keys.
                            # Mandatory: no
                            # Range: 1-1000
                            # Default:
                            # MaxLinesPerSecond=100
                            ### Option: AllowRoot
                            # Allow the agent to run as 'root'. If disabled and the agent is started by 'root', the agent
                            # will try to switch to user 'zabbix' instead. Has no effect if started under a regular user.
                            # 0 - do not allow
                            # 1 - allow
                            # Mandatory: no
                            # Default:
                            # AllowRoot=0
                            ############ ADVANCED PARAMETERS #################
                            ### Option: Alias
                            # Sets an alias for parameter. It can be useful to substitute long and complex parameter name with a smaller and simpler one.
                            # Mandatory: no
                            # Range:
                            # Default:
                            ### Option: Timeout
                            # Spend no more than Timeout seconds on processing
                            # Default:
                            ### Option: Timeout
                            # Mandatory: no
                            # Range: 1-30
                            # Default:
                            # Timeout=3
                            ### Option: Include
                            # Mandatory: no
                            # Default:
                            # Include=
                            Include=/etc/zabbix/zabbix_agentd.d/
                            # Include=/usr/local/etc/zabbix_agentd.userparams.conf
                            # Include=/usr/local/etc/zabbix_agentd.conf.d/
                            ### Option: UnsafeUserParameters
                            # Allow all characters to be passed in arguments to user-defined parameters.
                            # 0 - do not allow
                            # 1 - allow
                            # Mandatory: no
                            # Range: 0-1
                            # Default:
                            # UnsafeUserParameters=0
                            ### Option: UserParameter
                            # User-defined parameter to monitor. There can be several user-defined parameters.
                            # Format: UserParameter=<key>,<shell command>
                            # See 'zabbix_agentd' directory for examples.
                            # Mandatory: no
                            # Default:
                            # UserParameter=
                            • tob
                              • Dec 2008
                              • 25
                              #29
                              Hi rugwiza,
                              The logmessages you are seeing are not related to the issue of zabbix reporting 'not running' in the front-end. If you simply add a host 'Zabbix Server' (with a template I would think), the server will know what to monitor.
                              For your front-end issue: please read back to my earlier comment about selinux.
                              good luck, let us know how it goes!
                              • rugwiza
                                • Jan 2013
                                • 16
                                #30
                                zabbix not running
                                Thanks Tob,
                                I already added the zabbix server with its appropriate IP.
                                zabbix Server Applications (1) Items (0) Triggers (0) Graphs (0) Discovery (0) 10.8.10.32: 10050 - Monitored
                                According to the graph, it lloks to be monitored.
                                But the red alert persists:
                                zabbix server is not running....................
