Zabbix send old alert
  • cybergonz
    • Oct 2012
    Hi all,
    I'm using Zabbix 2.0.3 on my company. I have a very strange issue.
    Zabbix send me a lot of old alert by mail like that:
    Today (2012/10/15 @ 1:39 PM)
    Status : 2012.10.08 10:35:12 - OK.
    Trigger: [High] Tomcat is not running.
    Item : 10054.
    Value : *UNKNOWN*.
    Server notes: xxxx
    Trigger comment:
    How to avoid it ?
    This zabbix status:
    Parameter Value Details
    Zabbix server is running No localhost:10052
    Number of hosts (monitored/not monitored/templates) 382 287 / 24 / 71
    Number of items (monitored/disabled/not supported) 22460 11892 / 10120 / 448
    Number of triggers (enabled/disabled)[problem/unknown/ok] 4307 3876 / 431 [2 / 0 / 3874]
    Number of users (online) 40 4
    Required server performance, new values per second 131.76 -
    Thank in advance for your help and advice
  • cybergonz
    • Oct 2012
    I noticed the old alert content a Value : *UNKNOWN*.
    I have this value on each old alert.
    Thank you.
    • tchjts1
      • May 2008
      • 1605
      The "Unknown" value is being generated by the action you have set up for the alert.
      Go to Configuration --> Actions. See where it has 3 lines listed for item values?
      If you are only reporting on one value, the others will be "Unknown" in the alert.
      Remove the excess items from your actions.
      (Note: you also see in your above message that your Zabbix server is not running, right?)
      "Zabbix server is running No localhost:10052"
      • cybergonz
        • Oct 2012
        Thank you for your reply.
        Please to see my configuration of Actions (it's very simple).
        Default subject :
        [{TRIGGER.SEVERITY}] {HOSTNAME} - {TRIGGER.NAME}: {STATUS}
        Default message :
        Status : {EVENT.DATE} {EVENT.TIME} - {TRIGGER.STATUS}.
        Trigger: [{TRIGGER.SEVERITY}] {TRIGGER.NAME}.
        Item : {ITEM.NAME}.
        Value : {ITEM.VALUE}.
        Server notes: {PROFILE.NOTES}.
        Trigger comment: {TRIGGER.COMMENT}.
        Trigger url: {TRIGGER.URL}.
        • tchjts1
          • May 2008
          • 1605
          Ok, so this is your unknown item. . Try making that {ITEM1.VALUE}
          • cybergonz
            • Oct 2012
            Hi, I tested it but now I receved this text in the body of the mail alert :
            Status : 2012.09.18 10:53:49 - OK. <== still an old alert
            Trigger: [High] SQL Server is not running.
            Item : 1000.
            Value : {ITEM1.VALUE}. <== no value
            Server notes: *UNKNOWN*.
            Trigger comment: .
            Trigger url: .
            • cybergonz
              • Oct 2012
              For information, I recently migrated my Zabbix Server from the 1.8.12 to the 2.0.2 and now the 2.0.3.
              • cybergonz
                • Oct 2012
                I checked the value send from the zabbix agent to the zabbix server, and it's good (Latest data > Last check)
                • cybergonz
                  • Oct 2012
                  I noticed that the zabbix server always send this alerts since the first time it gets the value *UNKNOWN*.
                  This very strange
                  • cybergonz
                    • Oct 2012
                    I try the found the origine of my value *UNKNOWN* in the database.
                    Someone can tell me in which table is it store ?
