Action not working for windows clients?
  • LenR
    • Sep 2009
    • 1011
    I have an action that won't "activate". I have basically identical actions with the only difference being that the failing action is for a group of windows servers. The trigger works and shows on the dashboard & audit. Version is 1.8.10.
    The conditions are: not main and "problem" and host grouop = wingrp and severity >= "average". The action should send email to a group, the group is used in other actions and works. Escalation on/off doesn't seem to matter.
    Any ideas?
  • LenR
    • Sep 2009
    • 1011
    Forgot - all our windows servers are monitored via a proxy. I don't think it matters, but full disclosure
    • LenR
      • Sep 2009
      • 1011
      Further testing, a test action works that doesn't specify the host group. What could be poisonous in a host group to break actions?
      • LenR
        • Sep 2009
        • 1011
        If you're not getting notifications or actions aren't working, check RIGHTS. You have to have at least r/o to a system/group to get notifications.
        • jashley
          • Aug 2007
          • 37
          LenR,
          Did you get any help on this or did you get this resolved?
