Zabbix error in Action
  • rriscado
    • Mar 2013
    Good Night,
    I have a problem in the zabbix actions.
    I'm using version 2.0.5 of the zabbix server on a RedHat 5 with Mysql.
    My problem is the following:
    I create an action with a single operation(running a script on the host agent), but this operation goes from step 1 to 5, with delay between steps of 120 seconds.
    The problem is that if the corresponding trigger resolves, the action does not terminate its execution before all five steps are executed.
    An example, a trigger activated, the action also activated, the script was executed in step 1 and the trigger was resolved, this time the action should end as well, but it does not end and executes all other steps programmed.
    Am I doing something wrong or is a bug in zabbix?
    att
    Raphael Riscado
