Not sending email from Web Monitoring
  • carl_qin
    • May 2013
    • 11
    I have setup Web monitoring in zabbix 2.0.6 and created a trigger and action.In the action,I setup sending email out.Then I mandatory turned off monitored web site,I couldn't get alert email,but in Zabbix Monitoring -> Dashboard -> Web monitoring,it shows "failed".For sending email setup,it works in other scenario.For example, I can get alert email when I setup a monitored server CPU high.
    Thanks for any help.
  • Heilig
    • Mar 2013
    • 366
    Trigger fired? If not, please check trigger expression.
    If the trigger is fired, you need to check the action conditions.
    • carl_qin
      • May 2013
      • 11
      Thanks Heilig.I get it work.Most likely, it's due to trigger condition not configured correctly.
