External Websites Monitoring
  • uday
    • Jul 2013
    Using Zabbix I can monitor my intranet websites very easily, but monitoring external websites I am having difficulties. I want to monitor just simple HTTP uptime.
    For example : How do I monitor if HTTP is working on www.google.com ?
    Thanks in advance
  • BDiE8VNy
    • Apr 2010
    • 680
    There are several ways to achieve this. One way might be to use Simple checks.
    Keep in mind to configure the http_proxy / https_proxy environment variable(s) if necessary.
    • uday
      • Jul 2013
      Thanks BDiE8VNy,
      But, where do I set http_proxy / https_proxy environment variable(s).
      If I understand correctly it should be something like this but where to set ?
      http_proxy=http://proxy_ip: proxy_port.
      https_proxy=http://proxy_ip: proxy_port.
      Sorry... I am still new to Zabbix 2.0 the reason for above basic question.
      • BDiE8VNy
        • Apr 2010
        • 680
        I do it this way:
        [root@example ~]# sed -n 17,23p /etc/init.d/zabbix-server
        # Source function library.
        . /etc/rc.d/init.d/functions
        # Source sysconfig
        . /etc/sysconfig/zabbix
        [root@example ~]# cat /etc/sysconfig/zabbix
        HTTP_PROXY=http://http-proxy.example.com:8080/
        HTTPS_PROXY=$HTTP_PROXY
        http_proxy=$HTTP_PROXY
        https_proxy=$HTTPS_PROXY
        export        \
          HTTP_PROXY  \
          HTTPS_PROXY \
          http_proxy  \
          https_proxy
        [root@example ~]#
        Doing it this way needs the init script to be modified every time after an update of the Zabbix Server has been done.
