We have an Ubuntu 12.04LTS server running just Zabbix-MySQL with PHP front end. It was running 2.0 fine. I did an in-place upgrade to 2.20 using pre-compiled sources and everything seemed to go fine and it is up and running. However I have found an odd problem, which is I cannot add a new template to a host. I can remove an existing template no problem but when I press the "Add" link it just spins for a minute and does nothing else.
There are no errors in the GUI or in the /var/log/apache2/error.log file. However in the Zabbix server log on start up I see a bunch of apparently missing things like this:
No log handling enabled - turning on stderr logging
MIB search path: $HOME/.snmp/mibs:/usr/share/mibs/site:/usr/share/snmp/mibs:/usr/share/mibs/iana:/usr/share/mibs/ietf:/usr/share/mibs/netsnmp
Cannot find module (HOST-RESOURCES-MIB): At line 0 in (none)
1348:20131122:174658.106 wrong answer on RCPT TO [550 5.7.1 Unable to relay
Cannot find module (SNMPv2-SMI): At line 0 in (none)
1348:20131122:174733.129 wrong answer on RCPT TO [550 5.7.1 Unable to relay
Cannot find module (SNMPv2-MIB): At line 0 in (none)
1348:20131122:174739.618 wrong answer on RCPT TO [550 5.7.1 Unable to relay
Cannot find module (IF-MIB): At line 0 in (none)
1348:20131122:174814.687 wrong answer on RCPT TO [550 5.7.1 Unable to relay
1348:20131122:174849.709 wrong answer on RCPT TO [550 5.7.1 Unable to relay
1360:20131122:174958.051 cannot link template: template with item key "agent.hostname" already linked to the host
1360:20131122:175301.477 cannot link template: template with item key "agent.hostname" already linked to the host
1360:20131122:175304.517 cannot link template: template with item key "agent.hostname" already linked to the host
1360:20131122:175310.596 cannot link template: template with item key "agent.hostname" already linked to the host
1360:20131122:175313.734 cannot link template: template with item key "agent.hostname" already linked to the host
1360:20131122:180033.001 cannot link template: template with item key "agent.hostname" already linked to the host
1360:20131122:180336.419 cannot link template: template with item key "agent.hostname" already linked to the host
1360:20131122:180339.486 cannot link template: template with item key "agent.hostname" already linked to the host
1360:20131122:180345.552 cannot link template: template with item key "agent.hostname" already linked to the host
1360:20131122:180348.602 cannot link template: template with item key "agent.hostname" already linked to the host
1360:20131122:181107.487 cannot link template: template with item key "agent.hostname" already linked to the host
Any ideas how I can fix this please?
Thanks!
Thanks!
