Zabbix server is not running
  • Rohitmahajan701
    • Apr 2023
    #16
    The zabbix server is also not starting for me .. , Please see the logs :
    4659:20230425:171859.436 Got signal [signal:15(SIGTERM),sender_pid:583,sender_uid:0,rea son:0]. Exiting ...
    24701:20230425:171859.438 syncing history data in progress...
    24701:20230425:171859.438 syncing history data done
    24659:20230425:171859.460 syncing history data...
    24659:20230425:171859.461 syncing history data... 100.000000%
    24659:20230425:171859.461 syncing history data done
    24659:20230425:171859.461 syncing trend data...
    24659:20230425:171859.477 syncing trend data done
    24659:20230425:171859.477 Zabbix Server stopped. Zabbix 5.0.33 (revision 61a2f8278b1).
    Other than this , what is see via journalctl -xe is :
    Starting Zabbix Server...
    -- Subject: Unit zabbix-server.service has begun start-up
    -- Defined-By: systemd
    -- Support: http://lists.freedesktop.org/mailman.../systemd-devel
    -- Unit zabbix-server.service has begun starting up.
    Apr 26 18:08:46 centralized-monitoring-tool-sdwan zabbix_server[25922]: zabbix_server [25922]: user zabbixusr does not exist
    Apr 26 18:08:46 centralized-monitoring-tool-sdwan zabbix_server[25922]: zabbix_server [25922]: cannot run as root!
    Apr 26 18:08:46 centralized-monitoring-tool-sdwan systemd[1]: zabbix-server.service: control process exited, code=exited status=1
    Apr 26 18:08:46 centralized-monitoring-tool-sdwan systemd[1]: Failed to start Zabbix Server.
    -- Subject: Unit zabbix-server.service has failed
    -- Unit zabbix-server.service has failed.
      Heres your error.. check config. Wrong username to start service...
      • d3n4c3
        • Feb 2025
        It's very possible that you never uncommented or properly filled out the DBPassword= field in /etc/zabbix/zabbix_server.conf
