Zabbix server is not running
  • teddyg
    • Mar 2018
    Hi there,
    I am new to zabbix as well as linux so I may be overlooking something very basic. Your time taking a look at this is appreciated.
    I have built a CentOS 7 server and installed Zabbix 3.4.7.
    I am able to log in to the frontend successfully but get an message saying "Zabbix server is not running: the information displayed may not be current"
    I have tried to fix this with a few things;
    First by confirming the service is actually running on the server with systemctl status zabbix-server
    I have confirmed zabbix.conf.php and zabbix_server.conf have the same settings.
    I have run setsebool to change "httpd_can_network_connect", "httpd_can_connect_zabbix" and "zabbix_can_network" to "on"
    Through firewalld I have allowed port 10051 (and can confirm it is listed using firewall-cmd --zone=public --list-all)
    When I run "nmap -sT localhost -p 10051" the STATE is closed. I think that, that is where the root of the problem is but not sure how to fix it?
    Do I need to do any sort of config for port 10050?
    Again, I apprecate the time for assistnance. Thanks in advance.
    Last edited by teddyg; 20-03-2018, 06:59. Reason: included zabbix version. Added question about port 10050
  • teddyg
    • Mar 2018
    I have checked the zabbix_server.log file and it is filled with
    [Z3001] connection to database 'zabbix_db' failed: [1045] Access denied for user 'zabbix'@'localhost' (using password: YES)
    • vesper1978
      • Nov 2016
      • 59
      Can you connect to the DB using the zabbix user + pass from the zabbix server?
      • teddyg
        • Mar 2018
        Yes I believe so, when I enter in
        mysql -u zabbix -p zabbix_db
        and then enter in the password it connects through.
        Also want to include that I have installed everything on just the one server; frontend, db, server.
        When I check the grants for zabbix@localhost:
        GRANT ALL PRIVILEGES ON *.* TO 'zabbix'@'localhost' IDENTIFIED BY PASSWORD '*string of numbers and characters'
        GRANT ALL PRIVILEGES ON 'zabbix_db'.* TO 'zabbix'@'localhost'
        • teddyg
          • Mar 2018
          Figured the next step is to share my config files.
          /etc/zabbix/zannix_server.conf (these are all the uncommented entries found by
          grep -v '#' zabbix_server.conf
          LogFile=/var/log/zabbix/zabbix_server.log
          LogFileSize=0
          PidFile=/var/run/zabbix/zabbix_server.pid
          SocketDir=/var/run/zabbix
          DBName=zabbix_db
          DBUser=zabbix
          DBPassword='zabbixdbpass'
          SNMPTrapperFile=/var/log/snmptrap/snmptrap.log
          Timeout=4
          AlertScriptsPath=/usr/lib/zabbix/alertscripts
          ExternalScripts=/usr/lib/zabbix/externalscripts
          LogSlowQueries=3000
          /etc/zabbix/web/zabbix.conf.php
          // Zabbix GUI configuration file.
          global $DB;
          $DB['TYPE']     = 'MYSQL';
          $DB['SERVER']   = 'localhost';
          $DB['PORT']     = '0';
          $DB['DATABASE'] = 'zabbix_db';
          $DB['USER']     = 'zabbix';
          $DB['PASSWORD'] = 'zabbixdbpass';
          // Schema name. Used for IBM DB2 and PostgreSQL.
          $DB['SCHEMA'] = '';
          $ZBX_SERVER      = 'localhost';
          $ZBX_SERVER_PORT = '10051';
          $ZBX_SERVER_NAME = '';
          $IMAGE_FORMAT_DEFAULT = IMAGE_FORMAT_PNG;
          • huangyingja
            • Apr 2015
            • 27
            first ,
            1- check daemon zabbix-server running or not
            ps ax |grep zabbix
            2- check /var/log/zabbix/zabbix-server.log any error messages
            tail -f /var/log/zabbix/zabbix-server.log
            and start zabbix-server service
            3- check zabbix front-end config
            # cat /etc/zabbix/web/zabbix.conf.php
            $ZBX_SERVER = '10.10.10.10';
            zabbix front-end to zabbix server should be port 10051 , not 10050
            • teddyg
              • Mar 2018
              Originally posted by huangyingja
              first ,
              ps ax |grep zabbix
              1:
              750 ? Ss 0:00 avahi-daemon: running [zabbix.local]
              1184 ? S 0:03 /usr/sbin/zabbix_server -c /etc/zabbix/zabbix_server.conf
              1986 ? Ss 0:00 sshd: zabbix [priv]
              1991 ? S 0:00 sshd: zabbix@pts/0
              5361 pts/0 S+ 0:00 grep --color=auto zabbix
              2:
              Zabbix-server.service is running, checked with systemctl status zabbix-server.service
              3.
              global $DB;
              $DB['PORT'] = '0';
              $DB['SCHEMA'] = '';
              I also just disabled SElinux by editing /etc/sysconfig/selinux and rebooting.
              Checked sestatus and confirmed SELinux status: disabled
              Error still exists on frontend.
              I have reverted that change.
              • huangyingja
                • Apr 2015
                • 27
                <- please allow zabbix to query " zabbix_db "
                mysql> grant all privileges on zabbix_db.* to zabbix@localhost identified by 'zabbixdbpass';
                • teddyg
                  • Mar 2018
                  Thanks,
                  As mentioned above those privileges have already been granted:
                  When I do show grants for zabbix@localhost;
                  | Grants for zabbix@localhost |
                  | GRANT ALL PRIVILEGES ON *.* TO 'zabbix'@'localhost' IDENTIFIED BY PASSWORD '*4504DC3515313C63EE38C4A23A8DACA5DC306DA7' |
                  | GRANT ALL PRIVILEGES ON `zabbix_db`.* TO 'zabbix'@'localhost'
                  I removed the bottom grant and re-added it, flushing on the way and no change.
                  Have attached status on frontend incase that helps.
                  • belac
                    • Apr 2018
                    I am experiencing what appears to be the exact same issue. I will be watching this closely. thx
                    • -pinguin-
                      • Jun 2018
                      I found a solution.
                      See here:
                      • jsmalisa
                        • Aug 2019
                        I am getting this
                        support@tpng-zabbix-nms:~$ sudo systemctl status zabbix-server.service
                        ● zabbix-server.service - Zabbix Server
                        Loaded: loaded (/lib/systemd/system/zabbix-server.service; enabled; vendor preset: enabled)
                        Active: activating (auto-restart) (Result: exit-code) since Fri 2019-08-16 18:12:33 +10; 2s ago Process: 35579 ExecStart=/usr/sbin/zabbix_server -c $CONFFILE (code=exited, status=0/SUCCESS)
                        Main PID: 35594 (code=exited, status=1/FAILURE)
                        Aug 16 18:12:33 tpng-zabbix-nms systemd[1]: zabbix-server.service: Main process exited, code=exiteAug 16 18:12:33 tpng-zabbix-nms systemd[1]: zabbix-server.service: Failed with result 'exit-code'.
                        Tried restarting service but still same issue
                        • 1berto
                          • Sep 2018
                          • 182
                          What is in zabbix log files?
                          journalctl -xe
                          I have a similar problem, the server was up, but no new values were read, no log change, etc. It was a permission problem (in the log file), so i recreated it and everything went ok
                          • OzCuRo
                            • Aug 2019
                            You can test to upgrade cache size, works for me
                            • Acheron
                              • Feb 2020
                              I do have the same issue, and it got fixed.
                              My error:
                              In the Zabbix webpage, it shows
                              No
                              I found something like below in the logs.
                              connection to database 'zabbix' failed: [1130] Host 'zabbix.server.com' is not allowed to connect to this MariaDB server.
                              connection to database 'zabbix' failed: [1045]
                              both the error was due to the DB connectivity, in the /etc/zabbix/zabbix_server.conf file I used DBHOST as my server IP.
                              GRANT ALL PRIVILEGES ON zabbix.* TO zabbix@<IP> IDENTIFIED BY 'Your Password';
