Hello all!
I'm brand new to Zabbix. I just got it fully installed and the server piece configured today. I used the Zabbix Appliance iso. I have installed Zabbix onto a Hyper-V Virtual Machine and the installation seems to have been successful. I changed from dhcp to a static IP address and changed my timezone. Other than that, it should be exactly as it came. I started adding hosts and this is where things started to fall apart. The first host I attempted to add is a Windows Server 2012 R2 Virtual Machine hosted on a VMWare ESXi 6.5 box. I was able to get the agent installed and started, but I can't get it to communicate properly with the server. I've tried modifying the conf file, but to no avail. Here's the error I'm getting:
Get value from agent failed: ZBX_TCP_READ() failed: [104] Connection reset by peer
I've also tried adding a physical Windows Server 2012 R2 box, and I get the exact same result. What am I missing? The Windows firewall is disabled on the Hyper-V host and both the virtual machine and physical machine that I've installed the agent on. So what am I missing? I've done a tracert between the boxes and ensured that there are no additional hops, so I don't see how it could be an issue with a firewall...unless there is something going on with the Zabbix appliance itself, which I'm completely clueless on so far.
Any help would be greatly appreciate and thanks in advance!
-Brian
-Brian
