Close problem is disabled
  • FedericoCoppola
    • Jun 2018
    • 12
    I have a little problem with my Zabbix.
    I can not close my problems manually with the flag becouse it is disabled.
    My version of zabbix is 3.4.6.
    Someone can help me? Thanks
  • FedericoCoppola
    • Jun 2018
    • 12
    I have found a way but it is not global but for single trigger.
    Choosen an host > List triggers of this host > Select trigger about you are interested > On the top near "Discovered by" there is a link and click on it, so you can see the trigger prototipe > Choose the trigger prototipe > Now you can see the details about this trigger, scroll down and you can found the setting about "Allow manual close", flag it. Otherwise if this prototipe trigger is a dependecy on the top there is a link to the main template and flag the same setting in the main template.
    Is there a way to do this globally?
    Federico
