Problem Proxy Pfsense and Zabbix agent
  • sby
    • Jan 2017
    • 59
    HI,
    Can someone help me.
    I have create a Proxy server on pfsense that works zabbix
    Get value from agent failed: ZBX_TCP_READ() failed: [54] Connection reset by peer
    How can i fix this issue can someone help me.
  • kernbug
    • Feb 2013
    • 329
    Originally posted by sby
    HI,
    Hello
    Have you registered the proxy server address in the 'Server' and 'ServerActive' settings of the Zabbix Agent configuration file?
    • sby
      • Jan 2017
      • 59
      Yes i have try the external ip of the proxy and also the internal proxy gateway adress as proxy server adres in zabbix.
      But it is not working.
      • kernbug
        • Feb 2013
        • 329
        From Zabbix Agent host to the Zabbix Proxy host is it possible to do:
        telnet zabbix.proxy.host 10051
        • sby
          • Jan 2017
          • 59
          I get this from he internal ip.
          And also from the external ip.
          telnet 192.168.X.X 10051
          Trying 192.168.X.X...
          Connected to 192.168.X.X.
          Escape character is '^]'.
          Connection closed by foreign host.
          So there is something wrong i think then in pfesnse is that right.
          • sby
            • Jan 2017
            • 59
            Hi, I have worked now.
            Only how long to wait for it shows network graphs.
