Zabbix Backup Not Running :(
  • BSDUKJ
    • Aug 2017
    • 38
    My Zabbix Server is timing out due to the resource on the Zabbix Server.
    I know it's maxed out due to lack of memory and speed of disks, but I'm about to move it to a more powerful box but need to take a full database backup first.
    It did try stopping the zabbix-server.service for the duration of the back up it made no difference.
    I was thinking I need to stop the zabbix-agent.service on the Zabbix Server instead.
    I really just need to stop the connections to the box, any advice on what to stop to allow the backup to run?
    Kind Regards
    Jonny
  • dimir
    Zabbix developer
    • Apr 2011
    • 1080
    How about trying this thingie:
    Join the friendly and open Zabbix community on our forums and social media platforms.
    • BSDUKJ
      • Aug 2017
      • 38
      Originally posted by dimir
      Hi dmir,
      I did have a look at that but it's not been updated since 2016 and only tested up to 3.0.7.
      I'm using 3.4.5, does it backup everything?
      Cheers
      Jonny
      • LenR
        • Sep 2009
        • 1011
        I use this https://www.percona.com/software/mys...ona-xtrabackup
        It should work on any flavor of mysql. It has some options to throttle backup resource usage.
        • dimir
          Zabbix developer
          • Apr 2011
          • 1080
          Originally posted by BSDUKJ
          Hi dmir,
          Cheers
          Jonny
          Sorry, haven't used this one for quite some time. Perhaps it's not an option. But you could throw those guys a message, perhaps they just haven't been updating the version on github.
          • BSDUKJ
            • Aug 2017
            • 38
            I will do, as I need an automated process.
            It appears my issue was a timeout issue with the backup software I was using due to the amount of rows in the history_uint and trend_uint tables, a combined 80 Million Rows.
            So while the backup is not big in size it's the amount of rows that is causing my speed issue.
            I have found a workaround at the moment, albeit a manual process using SQLyog Community version
            I simply right click the Zabbix Database and choose the Backup/Export Option, select Structure and Data and backup.
            Contribute to sqlyog-community development by creating an account on GitHub.
