SNMP template for HP iLO and NAS-WD, Netgear
  • saquib akhtar
    • Aug 2018
    • 16
    Can anyone please provide me the SNMP templates for HP iLO utility monitoring, WD and Netgear NAS too.
    I got the attached document but it is not working in zabbix 3.4.11 on CentOS 7.5
  • Linwood
    • Dec 2013
    • 398
    I don't even try to monitor everything in ILO/Proliant, as there's SO much there.
    What I've found useful is to monitor just three indicators:
    cpqDaMibCondition 1.3.6.1.4.1.232.3.1.3.0 Array health
    cpqHeMibCondition 1.3.6.1.4.1.232.6.1.3.0 overall health (will flag also if anything in ILM)
    cpqSiMibCondition 1.3.6.1.4.1.232.2.1.3.0 system health
    From my experience once you know there's an issue you will end up going to the management home page anyway to see what it thinks, so why try to monitor the details it does so well on its own. If one of these flag, you go look. Simple, easy, and no need to update as new agent releases come out, or new hardware installed.
    Yes, it's a cheat.
    • saquib akhtar
      saquib akhtar commented
      By monitoring the iLO we can get temperature, and all other hardware status immediately.
      I am monitoring dell idrac via snmp in zabbix and it's absolutely amazing.
      Is there any template for iLO 4 ??
  • dimir
    Zabbix developer
    • Apr 2011
    • 1080
    If you haven't heard there's this thing https://share.zabbix.com where Zabbix users exchange different things like Templates, plug-ins etc. Here's what I've found by keywords like "ILO" and "HP":
    The Zabbix Team has collected all official Zabbix monitoring templates and integrations.
    but you can try your own search.
    • saquib akhtar
      I tried to import the file HP_ilo4_SNMP_agentless after downloading from github but it gave me error: Import failed
      Details
      Cannot import template "HP Server Health Template", linked template "Template ICMP Ping" does not exist. [conf.import.php:167 → CFrontendApiWrapper->import() → CApiWrapper->__call() → CFrontendApiWrapper->callMethod() → CApiWrapper->callMethod() → CFrontendApiWrapper->callClientMethod() → CLocalApiClient->callMethod() → call_user_func_array() → CConfiguration->import() → CConfigurationImport->import() → CConfigurationImport->processTemplates() → CTemplateImporter->import() in include/classes/import/CConfigurationImport.php:548]
  • dimir
    Zabbix developer
    • Apr 2011
    • 1080
    First import "Template ICMP Ping" and then try again.
    • saquib akhtar
      • Aug 2018
      • 16
      I renamed the template module ICMP ping to TEMPLATE ICMP PING and then tried to import HP iLO template and got a new error:
      • Trigger prototype "RAID Controller [{#SNMPVALUE}] need check (Other)" depends on trigger "{HOST.NAME} is unavailable by ICMP", which does not exist. [conf.import.php:167 → CFrontendApiWrapper->import() → CApiWrapper->__call() → CFrontendApiWrapper->callMethod() → CApiWrapper->callMethod() → CFrontendApiWrapper->callClientMethod() → CLocalApiClient->callMethod() → call_user_func_array() → CConfiguration->import() → CConfigurationImport->import() → CConfigurationImport->processDiscoveryRules() → CConfigurationImport->processTriggerPrototypeDependencies() in include/classes/import/CConfigurationImport.php:1244]
      • dimir
        Zabbix developer
        • Apr 2011
        • 1080
        The error message clearly tells you that you are missing trigger "{HOST.NAME} is unavailable by ICMP" which should be coming from ICMP template. Please use Comments under this Template on share.zabbix.com or try another one. I'm not the author of this Template so I have no idea of how to use it properly.
        • saquib akhtar
          • Aug 2018
          • 16
          How can I create this trigger manually ?
          • dimir
            Zabbix developer
            • Apr 2011
            • 1080
            Describe your problem to the Template owner here: https://share.zabbix.com/cat-server-...imple-template
            • saquib akhtar
              • Aug 2018
              • 16
              Done but is there any expected time of reply from them ?
              And can you just tell me how can I create a trigger for {HOST.NAME} is unavailable by ICMP
              • dimir
                Zabbix developer
                • Apr 2011
                • 1080
                • saquib akhtar
                  • Aug 2018
                  • 16
                  Can you help me to create this trigger so that I can do with HP iLO monitoring.
                  No one has replied from author side for that template on https://share.zabbix.com/cat-server-...imple-template
                  • dimir
                    Zabbix developer
                    • Apr 2011
                    • 1080
                    I gave you the link to instructions on how to create a trigger? What is unclear there?
                    If you have some specific problems setting up monitoring you should consider our commercial support
                    Zabbix Subscriptions pair expert support commitments with a predictable subscription model for your business operations.
                    or training
                    Zabbix certified training is the fastest way to gain expertise, no matter what your current knowledge level.
