Upgrade Problems and troubleshooting from 3.4.15 to 4.0 (repository and Database)
  • carsa81
    • Jul 2018
    • 10
    Hi
    I Just upgrade my Zabbix Server from 3.4.15 to 4.0.0 (on my Centos7.5 mysql/apache)
    I want share some problems and fix that I used.
    I follow this Guide: https://www.zabbix.com/documentation...es/rhel_centos
    First problem: Repository Zabbix 4.0 are not seen
    FIX:
    • Use > sudo yum clean all > sudo rm -rf /var/cache/yum > sudo yum repolist > then perform sudo yum update/upgrade -y
    Second Problem: DB upgrade failed
    FIX:
    1. check the log sudo cat /var/log/zabbix/zabbix_server.log
    2. On logs: "[Z3005] query failed: [1060] Duplicate column name 'severity' [alter table `events` add `severity` integer def ault '0' not null]'
    3. According with this Issue https://support.zabbix.com/projects/...lter=allissues I removed the severity value in the events table.
      1. mysql -u USER -P
      2. use DB-ZABBIX;
      3. ALTER TABLE events DROP COLUMN severity;
      4. exit
    4. sudo systemctl start zabbix-server.service
    5. check log and try to login on dashboard
    I hope this will be useful to someone.
  • sancho
    • Mar 2015
    • 301
    Use > yum clean all > rm -rf /var/cache/yum > yum repolist > the perform yum update/upgrade -y
    Thank you very much carsa81
    You have saved me a headache.
    • Mun
      • Sep 2016
      • 67
      Originally posted by carsa81
      Hi
      FIX:
      FIX:
        1. mysql -u USER -P
        2. use DB-ZABBIX;
        4. exit
      Thanks! Your solution works for me.
      • hugosantos
        • Dec 2016
        Thanks for this.
        • tealsteam
          • Dec 2018
          Thanks very much, this helped a treat!
