Not getting latest zabbix 4 version
  • Captain_Paralytic
    • Sep 2018
    • 19
    Hi there,
    I'm following the instructions on the page https://www.zabbix.com/documentation.../debian_ubuntu but when I check after issuing the upgrade command, I'm only getting the version:
    zabbix-server-mysql - 1:4.0.0rc3-1+stretch
    Interestingly after running the command
    dpkg -i zabbix-release_4.0-2+stretch_all.deb
    I am not seeing the zabbix.list file in /etc/apt/soures.list.d/ either.
    I've manually copied the zabbix.list file from the package and tried a fresh install but I'm still only getting the rc3 version.
    Any ideas anyone?
  • Captain_Paralytic
    • Sep 2018
    • 19
    So I've just gone over to http://repo.zabbix.com/zabbix/4.0/de...main/z/zabbix/ and have downloaded the correct deb files and have installed them manually using "dpkg -i". Would really like to know why the upgrade via apt isn't working properly though.
    • Atsushi
      Atsushi commented
      Have you updated apt's cache after installing the latest version of zabbix-release package?
      ex.
      $ sudo apt update
  • Captain_Paralytic
    • Sep 2018
    • 19
    Hi Atushi,
    Yes I did. As I said originally I followed through the instructions on the linked page. An apt/apt-get update is automatic to me (as I'm sure it is to you), but thanks for checking with me.
    • Atsushi
      Atsushi commented
      When referring first, were not the following packages?
      zabbix-release_4.0-1+stretch_all.deb
      There is a problem, the following packages are released immediately after.
  • Captain_Paralytic
    • Sep 2018
    • 19
    Hi Atushi,
    Yes I realised that. So I re-did it with the latest ones before making this post. Same problem I'm afraid, hence me manually downloading the deb files. I was hoping that the actual release (as opposed to thr rc3 one) would fix the problem I am seing with dupilcate emails being sent but that is also still a problem.
    • zux
      • Sep 2018
      • 97
      there is a bug report about this:
      see discussion there
