I am having issues related to flexible intervals on two installations since upgrading from 2.0.1 to 2.2.3.
The problem is, it appears I can no longer use them. If I attempt to set the "Update interval" to 0, then attempt to define a flexible interval (Interval: 86400 | Period: 1-7,08:00-08:01 as an example) I receive the following error:
"Item will not be refreshed. Please enter a correct update interval."
I would also like to note that items that I had previously configured with flexible intervals are no longer pulling data during those intervals (or at all for that matter). My graphs are blank and the "latest data" tab of the UI shows no updates for any of those items since the update.
I have also attempted to update non interval related objects in my previously defined items (that used to work just fine with flexible intervals) and when I attempt to save I receive the error mentioned above about entering a correct update interval.
I am hoping I am just missing something simple, however, I'm not seeing it. Any help is greatly appreciated.
