server reporting its agent is unreachable then resolves a few min later repeatadly
My zabbix templates https://github.com/kloczek/zabbix-templates -
I have similar issue on ver 4.0.5 what makes mine even worse on a lot of them I have the resolve time anywhere from 7min to -6min so yes on some it resolves the issue up to 6min before logging the fault on it.
I have gone through all logs and all configs. Network is stable, All servers are running of same NTP servers and on my Zabbix cluster we are less than 2ms difference in time at most. DB server performance is fine. The only thing on my side is all my servers are monitored through Proxies (They use same NTP servers and there performance is fine) and all my agents are different versions as we have not done to many changes on our agents so they currently vary from ver 2.8 to 3.4
I am desperate at this stage as I do not know where to look anymore4 Zabbix Frontend Servers (Load balanced)
2 Zabbix App Servers (HA)
2 Zabbix Database Servers (HA)
18 Zabbix Proxy Servers (HA)
3897 Deployed Zabbix Agents
6161 Values per second
X-Layer Integration
Jaspersoft report Servers (HA)Comment
