Software invenory with Zabbix
  • AlessandroInfo
    • Mar 2019
    • 55
    Hi everyone,
    I'm new and just threw myself into the world of Zabbix ... and I'm having the first difficulties.
    I downloaded and started the Zabbix 4.0.5 appliance on Ubuntu, as a virtual machine on Hyper-V.
    I installed the agent on my laptop to test Zabbix's automatic inventory function. On Zabbix I created the host referred to my pc, enabled the automatic inventory function from the "host inventory" tab and created the item that uses the "system.sw.packages" key linking it to a field to always fill in "Host inventory" tab. I do not understand how to compile correctly the key, since it does not give me any data.
    Instead, the operating system was correctly detected and the field that I assigned to it compiled (but this using a template already configured in Zabbix). So I don't think it's an interface problem with the agent, also because I see it online.
    I've tried putting the key "system.sw.packages [all, all, full]" (settings that if I haven't mistake should be default), but nothing changes. I have no error, no signal, nothing. I just can't find directions on how to set it up ...
    Thank you for your support.
    Alessandro
  • dimir
    Zabbix developer
    • Apr 2011
    • 1080
    Which host inventory field are you trying to fill with value of item system.sw.packages? Host inventory fields have different size limits.
    • AlessandroInfo
      • Mar 2019
      • 55
      Hello, I tried the field "Software (full detail)"
      • dimir
        Zabbix developer
        • Apr 2011
        • 1080
        Which Type of information is set in the item system.sw.packages ? It must be set to Text.
        If you go to Configuration -> Latest data, do you see the last value of that item? Check the Show items without data and Show details checkboxes, do you see a red error icon in the Info column?
        • AlessandroInfo
          • Mar 2019
          • 55
          Hi, I installed this mornig Zabbix from package and try now to reconfigure my items. Let me time to try and write later here.
          I used the appliance first (that I deleted). The type of information was set to text, as requested.
          • AlessandroInfo
            • Mar 2019
            • 55
            Hi, from https://www.zabbix.com/documentation...ed_by_platform, I'm reading now that Windows client not support this key... and my client in only on Windows.
            Too bad, because it was useful. Looking for the key agent, I didn't understand it...
            Thank you for youre help.
