I'm trying to use host discovery in Zabbix but have some weird problem with fping.
The discovery rule is configured like this:
IP range: 192.168.7.1-254
Delay: 7200 seconds
Checks: ICMP ping
Enabled: Check
Zabbix shows no hosts in Monitoring-Discovery. Although, every 2 hours I see a series of lines in zabbix_server.log like this:
The lines mention all live hosts. I suppose, the discovery process is working as intended but something prevents it from interpreting fping output correctly. Though I have a ton of active items pinging many hosts via icmpping[] and icmppingsec[] keys working perfectly on the same server.
Upgraded Zabbix from 2.0.5 to 2.2.4 - still the same problem.
Upgraded fping from 3.4 to 3.10 - still no change.
Zabbix server runs on FreeBSD 8.4/i386 in a Hyper-V virtual machine. I remember the discovery working some months ago when the system was just installed initially but have no idea what change broke it and when.
Any ideas?
Delay: 7200 seconds
Checks: ICMP ping
Enabled: Check
.... 24380:20140626:114402.679 fping failed: "192.168.7.56 : [1], 84 bytes, 2.15 ms (1.99 avg, 0% loss)" 24380:20140626:114406.900 fping failed: "192.168.7.57 : [1], 84 bytes, 2.04 ms (1.97 avg, 0% loss)" 24380:20140626:114430.065 fping failed: "192.168.7.62 : [1], 84 bytes, 2.57 ms (2.61 avg, 0% loss)" 24380:20140626:114443.992 fping failed: "192.168.7.65 : [1], 84 bytes, 2.14 ms (2.00 avg, 0% loss)" 24380:20140626:114446.736 fping failed: "192.168.7.66 : [1], 84 bytes, 1.97 ms (1.77 avg, 0% loss)" 24380:20140626:114450.691 fping failed: "192.168.7.67 : [1], 84 bytes, 2.24 ms (1.98 avg, 0% loss)" ....
Any ideas?
