Insufficient file system permissions. Assets cache directory is not writable.
  • ma-kom
    • May 2019
    After updating zabbix and restarting the system I got this error message, when trying to open the web interface.
    Insufficient file system permissions. Assets cache directory is not writable. <retry>
    I can not access the zabbix interface. Where can I find the Assets Cache Directory?
    Refers to version 4.0.8-1+bionic
    SOLVED:
    sudo chmod -R 777 /usr/share/zabbix/assets
  • knarf
    • May 2019
    Great, that did the trick. Adding the web server's user to the group of the assets directory would also do the trick, I guess.
    Had another issue though after the update to version 4.0.8-1+bionic, all graphs did show without text. I found out that it had to do with a missing font file in the assets/fonts folder. Any ttf will do, I copied DejaVuSans to the default name graphfont, so I didn't have to edit the defines.inc.php file as suggested here: https://www.zabbix.com/forum/zabbix-...s-missing-text
    /usr/share/fonts/truetype/dejavu/DejaVuSans.ttf /usr/share/zabbix/assets/fonts/graphfont.ttf
    • Piet Loef
      • Mar 2019
      ln -s /usr/share/zabbix/fonts/graphfont.ttf /usr/share/zabbix/assets/fonts/
      • wts_tim
        • May 2019
        I am currently running CentOS 7, Zabbix updated these four packages last night and no longer able to access the log in page as i see the same error message above.
        May 29 03:24:38 Updated: zabbix-web-mysql.noarch 4.0.8-1.el7
        May 29 03:24:40 Updated: zabbix-web.noarch 4.0.8-1.el7
        May 29 03:24:41 Updated: zabbix-server-mysql.x86_64 4.0.8-1.el7
        May 29 03:24:41 Updated: zabbix-agent.x86_64 4.0.8-1.el7
        I have tried changing the permissions to 777 and changing the owner to apache but this makes no difference for my setup.
        • romale
          • Mar 2013
          • 53
          Originally posted by ma-kom
          SOLVED:
          Works for me too. Thanks
          • Nevn
            • May 2019
            I do had to set some SELinux permissions as well to get it working
            • wts_tim
              • May 2019
              Nevn, do you recall the commands/what you changed in regards to SELinux?
              • Nevn
                Nevn commented
                ausearch -c 'httpd' --raw | audit2allow -M my-httpd
                semodule -i my-httpd.pp
                This is what I had to do.
            • liedekef
              • May 2005
              • 10
              Wille chmod and selinux fixes are ok, no service should be writing in /usr. That's why /var has been invented ... Even the chmod itself should not be needed, it just means there's something wrong with the package.
              • Nevn
                • May 2019
                This directory is only supposed to exist from Zabbix 4.2.2 so there is definitely an issue,
                I checked my backup and before the update there was no assets directory
                • mustapha.aisssat
                  • May 2019
                  On CentOS 7, I fix this issue by adding RW permission to apache by :
                  # setfacl -d -m apache:rwX /usr/share/zabbix/assets/
                  # setfacl -R -m apache:rwX /usr/share/zabbix/assets/
                  and Selinux problems by :
                  # semanage fcontext -a -t httpd_sys_rw_content_t "/usr/share/zabbix/assets(/.*)?"
                  # restorecon -R /usr/share/zabbix/assets
                  • hiquer
                    • Feb 2019
                    SOLVED:
                    My is CentOS7.
                    Solved for me. Thanks
                    • wts_tim
                      • May 2019
                      Thanks! This resolved my issue.
                      • Fregi Ventum
                        • May 2019
                        Thanks mustapha.aisssat. Though this resolved the login issue for me, all of the graph labels were missing.
                        Since I'm not a fan of arbitrarily doing recursive chmod 777s, I reverted to the snapshot taken prior to upgrade. I hope this will be resolved shortly.
                        • Fregi Ventum
                          • May 2019
                          You hit the nail on the head liedekef.
                          • carmichael.chris
                            • May 2019
                            If you don't wanna go scorched earth, my coworker Forkner solved it a little safer. ;-)
                            chown -R apache /usr/share/zabbix/assets/
                            • ksookhai
                              ksookhai commented
                              Thank you Kindly Carmichael.chris and your coworker Forkner. Worked like a charm.
