Insufficient file system permissions. Assets cache directory is not writable.
  • sancho
    • Mar 2015
    • 301
    #16
    Originally posted by ma-kom
    SOLVED:
    sudo chmod -R 777 /usr/share/zabbix/assets
    Thanks ma-kom
    • chopard
      • May 2019
      Originally posted by mustapha.aisssat
      On CentOS 7, I fix this issue by adding RW permission to apache by :
      # setfacl -d -m apache:rwX /usr/share/zabbix/assets/
      # setfacl -R -m apache:rwX /usr/share/zabbix/assets/
      and Selinux problems by :
      # semanage fcontext -a -t httpd_sys_rw_content_t "/usr/share/zabbix/assets(/.*)?"
      # restorecon -R /usr/share/zabbix/assets
      Work for me in Centos 7 and Zabbix 4.2.2
      • mbuyukkarakas
        • Aug 2014
        • 49
        #18
        Hello all,
        I had the same problem on my Centos 7, Zbx 4.2.2 server. I applied all the selinux commands but not solved my issue. I had to revert to taken snapshot.
        Fyi.
        Mehmet
        • mbuyukkarakas
          mbuyukkarakas commented
          Unfortunately a dirty solution worked.
          # chmod -R 775 /usr/share/zabbix/assets
      • Infra_HDC
        • May 2019
        Hello, thanks for this topic start.
        Under Ubuntu 18.04 LTS, I did this to solve the problem:
        sudo chgrp -R www-data /usr/share/zabbix/assets
        sudo chmod -R g+w /usr/share/zabbix/assets
        • Carlo
          Carlo commented
          Hi. Thanks.
          This solved the problem.
        • maruscya
          maruscya commented
          Thanks.
          It works fine.
      • Fregi Ventum
        • May 2019
        4.2.3 is out and it successfully upgraded 4.2.1 without issue for me, whereas I rolled back from snapshot the 4.2.2 upgrade.
        • onionsgalore
          • May 2019
          #21
          Where do you see 4.2.3 being out?
          e: nvrm I see it on repo.zabbix.com now.
