Thanks for the reply vso. I am sure its a bug, but to open a report it says i need to have some login which i don't have.
As i stated above, i have provided all the logs, and if you need more i can give more too.
Ok, so looks like i am not clear in providing info, here i re iterate again.
My old system was 3.0.13 (all in one, DB, engine and WebUI). Here are the details. - This is before upgrade -
More Details
This above is working fine and as expected - close to 18months, And i thought of upgrading , here is the upgraded system. (DB in one machine, WebUI and Engine in another.)
And system details
In the upgrded i have enabled only certain hosts. Not all, about 20 hosts for testing. Now out of these 20, some are hitting problems and they are genuine alerts.
Only problem is
- Alerts are triggering emails which is more than expected.
- Somewhere Any action which is initiated by trigger is firing actions - which is not only for that trigger but also from other actions as well
- This is where i am seeing more than required amount of emails going through one action.
Since i can't attach all the images here, i am going to do reply to this thread.
Bottomline after upgrade from 3.0.13 to 4.0.7 LTS via compiling source -
Question : Is triggers are firing when there's a actual problem - Yes
Question : Is corresponding action is firing when theres a trigger - Yes
Question : Is action which has email sending enabled working for configured user group - Yes
So what's the problem - Problem is , in addition to configured email sending action, there are some more ( 30+ ) emails are getting fired with the action body - yes same action body , see my previous threads for the pics - i.e Let's say Action A to be fired for Trigger A, and email to be sent for user group B and C, in addition to this action body of E, F, G , H ...actions are also getting fired for the email group B & C. This is causing , for one trigger (PROBLEM or OK state) i am seeing 30+ emails getting fired where it suppose to only two - beacuse user group configured to receive email is only two.
Question : Is this happening to only specific triggers or all of the 337? As of now i have enabled 20 hosts for monitoring and most of the hosts have PROBLEMS coming in and this is happening for all of them.
Since the log files are huge, i can't upload it here.
Hope i am able to provide context, please let me know if more logs needed.
Log file - which clearly has multiple action email initiated for a trigger function evaluated .
Thanks,
zabbix_server (Zabbix) 3.0.13 Revision 74336 7 November 2017, compilation time: Dec 22 2017 06:02:28
[TABLE] [TR="class: cke_show_border"] [TD]Zabbix server is running[/TD] [TD]Yes[/TD] [TD]localhost:10051[/TD] [/TR] [TR="class: cke_show_border"] [TD]Number of hosts (enabled/disabled/templates)[/TD] [TD]6577[/TD] [TD]3135 / 2952 / 490[/TD] [/TR] [TR="class: cke_show_border"] [TD]Number of items (enabled/disabled/not supported)[/TD] [TD]22218[/TD] [TD]19403 / 2276 / 539[/TD] [/TR] [TR="class: cke_show_border"] [TD]Number of triggers (enabled/disabled [problem/ok])[/TD] [TD]7861[/TD] [TD]7092 / 769 [210 / 6882][/TD] [/TR] [TR="class: cke_show_border"] [TD]Number of users (online)[/TD] [TD]93[/TD] [TD]6[/TD] [/TR] [TR="class: cke_show_border"] [TD]Required server performance, new values per second[/TD] [TD]65.46[/TD] [/TR] [/TABLE] Number of actions : 337.
zabbix_server (Zabbix) 4.0.7 Revision 92831 18 April 2019, compilation time: Jun 3 2019 15:59:42 This product includes software developed by the OpenSSL Project for use in the OpenSSL Toolkit (http://www.openssl.org/). Compiled with OpenSSL 1.0.2k-fips 26 Jan 2017 Running with OpenSSL 1.0.2k-fips 26 Jan 2017
[TABLE] [TR="class: cke_show_border"] [/TR] [TR="class: cke_show_border"] [TD]Yes[/TD] [TD]localhost:10051[/TD] [/TR] [TR="class: cke_show_border"] [TD]6576[/TD] [TD]32 / 6054 / 490[/TD] [/TR] [TR="class: cke_show_border"] [TD]43947[/TD] [TD]973 / 42943 / 31[/TD] [/TR] [TR="class: cke_show_border"] [TD]13229[/TD] [TD]302 / 12927 [12 / 290][/TD] [/TR] [TR="class: cke_show_border"] [TD]92[/TD] [TD]1[/TD] [/TR] [TR="class: cke_show_border"] [TD]2.62[/TD] [TD] [/TD] [/TR] [/TABLE]
Only problem is
Thanks,
