Some of the screenshots for actionid 295, 365, 425,294, 181
Multiple cross emails from actions upgrade from 3.0 to 4.0.7 : broken
Just to add, these actions doesn't have conditions. Looks like , either hosts associated with these are deleted or triggers deleted. means these are actions without conditions. But that shouldn't be an issue right, system can have blank actions without conditions in them.
Problem is these are being matched for every trigger firing.
The issue is because of actions that don't have conditions, meaning that they are executed unconditionally.Comment
I don't think its happening on my 3.0.13 , i am attaching screentshot of events.
BTW what's the solution here? Is this a bug or not? Will there be a fix?
ALSO, once upgraded, i am not seeing problems beoyond current day. Even on the filters if i select 14 days older, i am not seeing problems. How to get earlier problems?2 PhotosComment
In 3.0.x its events, and in 4.0.x its clubed to problems (triggers + events ) i guess.
BTW , shouldn't it be not executing blank actions - it should be like match what's matching and execute only configured ones, why is it matching all the actions and executing blank ones?
Also how about viewing all the problems in 4.0.x? I am not able see problems beyond today.Comment
vso - I am not sure how the logic built in the backend but generally
- If i create an action , it should get execute for matched triggers, not for anything else.
- If there's any blank actions, since there's no trigger associated with it, it shouldn't get execute at all.
At the end of the day, actions are suppose to be depend on trigger.
I will tell you why this situation may occur.
- Today, you allow to delete a host, but not its associated triggers ( not sure if this is fixed now, had seen this sometime back may be 2.2.x or not sure actual version)
- When i go and delete a trigger on a template, as of now, actions associated to that trigger is not deleted, instead action remains but trigger linked to that action gets deleted and hence there remains blank action.
Ideally - if i delete a host , all the things associated to that host should get unlinked. i.e Template should get unlinked (but remains in background - template is independently created ) and host to be deleted.
Thanks,Comment
