Goodafternoon, guys
I recently configuration zabbix to accept SNMP traps using the following HOWTO located at https://www.zabbix.org/wiki/Start_wi...raps_in_Zabbix . I configured everything including the LLD for interface linkUp /linkDown traps. However I am running into a problem with the triggers expressions.
But the trigger don't match and I can't get the #SNMPVALUE
What I want is get the #snmpvalue and put the info in the trigger name to show the interface when the status changed.
The trigger expression is exactly as specified in the HOWTO
: {SNMP TRAP:snmptrapsnmptrap["(IF-MIB::linkDown|IF-MIB::linkUp)(.|[[:space:]])*{#SNMPVALUE}"]==1
When I delete the "(.|[[:space:]])*{#SNMPVALUE}" I can get the result and the trigger works
ZBXTRAP xxxxxxx
PDU INFO:
notificationtype TRAP
version 1
receivedfrom UDP: [xxxxxxxxx]:64162->[xxxxxxx]:162
errorstatus 0
messageid 0
community trapmonitor
transactionid 114
errorindex 0
requestid 0
VARBINDS:
DISMAN-EVENT-MIB::sysUpTimeInstance type=67 value=Timeticks: (543314742) 62 days, 21:12:27.42
SNMPv2-MIB::snmpTrapOID.0 type=6 value=OID: IF-MIB::linkDown
IF-MIB::ifIndex.47 type=2 value=INTEGER: 47
IF-MIB::ifAdminStatus.47 type=2 value=INTEGER: 2
IF-MIB::ifOperStatus.47 type=2 value=INTEGER: 2
IF-MIB::ifDescr.47 type=4 value=STRING: "XGigabitEthernet0/0/42"
How can I show that value=STRING: XGigabitEthernet0/0/42" in trigger name?
Thank you.
ZBXTRAP xxxxxxx
PDU INFO:
version 1
errorstatus 0
messageid 0
transactionid 114
errorindex 0
requestid 0
VARBINDS:
Thank you.
