Hello and thank you for your input on this thread.
I have recently added a third child in my Zabbix DM configuration.
During the first few hours after set up all was nice and dandy. After the weekend I have discovered that the child was not syncing properly. It is receiving the configuration updates from the master but I cannot tell from the logs that it does anything with them.
Here are the logs on the master:
6724:20140728:144818.402 NODE 1: sending configuration changes to slave node 12 for node 12 datalen 13229230
6724:20140728:144921.081 NODE 1: sending configuration changes to slave node 12 for node 12 datalen 13228736
6721:20140728:150056.359 NODE 1: sending configuration changes to slave node 12 for node 12 datalen 13228736
6721:20140728:150556.360 NODE 1: cannot receive answer from Node [12]: ZBX_TCP_READ() failed: [4] Interrupted system call
And the slave:
2582:20140728:144912.574 NODE 12: sending configuration changes to master node 1 for node 12 datalen 1543
2582:20140728:144934.711 NODE 12: Received configuration changes from master node 1 for node 12 datalen 13228736
2582:20140728:150046.820 NODE 12: sending configuration changes to master node 1 for node 12 datalen 4873
2582:20140728:150117.111 NODE 12: Received configuration changes from master node 1 for node 12 datalen 13228736
The "ZBX_TCP_READ()" failure seems to be caused by the child itself that sends a RST back to the master after 5 minutes. Can't tell why.
I see the data sent by the master in the child's log with debug level 4, but it does not log anything about doing something with it. Hence every 10-12 minutes, the master keeps sending the same data.
Also the same child seems to be having issues sending the history and trends to the master (currently the master is missing the last 36 hours of history from this child).
All servers are running Zabbix 2.2.3 (master on Red Hat and the rest of the children on Solaris 10).
Does anybody have any idea why this child ignores the configuration updates?
And the slave:
