item with multiple values
  • tomaskovicmarcel
    • Aug 2019
    • 9
    Hi guys,
    I have zabbix agent and I need send mulitple values with one item. For exaple:
    I have check: check_data_cache
    output is: 500 690 470
    Haw I can use/read this data from zabbix server and create graph with this data?
    Thank you!
    Marcel
  • Hamardaban
    • May 2019
    • 2714
    I will add to splitek : you can extract values in dependent elements using regex. In a more complex case, you can pass in zabbix json with values and use jsonpath preprocessing.
