zabbix will not restart upon upgrade
  • terrywhitejr2000
    • Aug 2014
    Upgraded to the version
    zabbix-server-2.2.5-1.el6.x86_64
    zabbix-2.2.5-1.el6.x86_64
    zabbix-server-mysql-2.2.5-1.el6.x86_64
    zabbix-web-2.2.5-1.el6.noarch
    zabbix-web-mysql-2.2.5-1.el6.noarch
    zabbix-agent-2.2.5-1.el6.x86_64
    This is the error I am getting from the logs
    ==> /var/log/zabbix/zabbix_server.log <==
    1813:20140811:174735.302 VMware monitoring: YES
    1813:20140811:174735.302 Jabber notifications: YES
    1813:20140811:174735.302 Ez Texting notifications: YES
    1813:20140811:174735.302 ODBC: YES
    1813:20140811:174735.302 SSH2 support: YES
    1813:20140811:174735.302 IPv6 support: YES
    1813:20140811:174735.302 ******************************
    1813:20140811:174735.302 using configuration file: /etc/zabbix/zabbix_server.conf
    1813:20140811:174735.416 [Z3005] query failed: [1286] Unknown table engine 'InnoDB' [select mandatory,optional from dbversion]
    1813:20140811:174735.416 Cannot get the database version. Exiting ...
  • Koral
    • Oct 2012
    • 30
    Have you tried downgrading to previous version?
    Is there anything in mysql logs?
    • terrywhitejr2000
      • Aug 2014
      ==> mysqld.log <==
      140812 5:13:47 InnoDB: Completed initialization of buffer pool
      InnoDB: Unable to lock ./ib_logfile0, error: 11
      InnoDB: Check that you do not already have another mysqld process
      InnoDB: using the same InnoDB data or log files.
      InnoDB: Error in opening ./ib_logfile0
      140812 5:13:47 [ERROR] Plugin 'InnoDB' init function returned error.
      140812 5:13:47 [ERROR] Plugin 'InnoDB' registration as a STORAGE ENGINE failed.
      140812 5:13:47 [Note] Event Scheduler: Loaded 0 events
      140812 5:13:47 [Note] /usr/libexec/mysqld: ready for connections.
      Version: '5.1.73' socket: '/var/lib/mysql/mysql.sock' port: 3306 Source distribution
      • terrywhitejr2000
        • Aug 2014
        Yes, I did try to downgrade.... I even restored the entire system for giggles.
        • terrywhitejr2000
          • Aug 2014
          So this is what I am getting from the web
          Database error
          The frontend does not match Zabbix database. Current database version (mandatory/optional): 0/0. Required mandatory version: 2020000. Contact your system administrator.
          and this is now in the mysql log
          140813 19:47:05 [ERROR] Plugin 'InnoDB' init function returned error.
          140813 19:47:05 [ERROR] Plugin 'InnoDB' registration as a STORAGE ENGINE failed.
          140813 19:47:05 [Note] Event Scheduler: Loaded 0 events
          140813 19:47:05 [Note] /usr/libexec/mysqld: ready for connections.
          • bbrendon
            • Sep 2005
            • 873
            Did I miss something? What version are you upgrading from?
            Unofficial Zabbix Expert
            Blog, Corporate Site
            • Koral
              • Oct 2012
              • 30
              Have you tried googling with this errors?
              There is something about deleting/moving ibdatalog files and restarting mysql - have you tried this?
              Or maybe I misunderstand - the mysql service alone is starting but with those errors?
              • cookiemonster
                • Jul 2014
                Originally posted by terrywhitejr2000
                ==> mysqld.log <==
                distribution
                I would check for permissions on the mysql files for the MySQL user.
                Also check this for possible solution http://dbhk.wordpress.com/2012/02/27...ile0-error-11/
                Your issue is not zabbix, but the database itself.
                • troffasky
                  • Jul 2008
                  • 640
                  I had this, and it was caused by Zentyal packages dropping a file with
                  innodb = off
                  into /etc/mysql/conf.d
                  Cue much confusion, as everything MySQL-based other than Zabbix worked fine. It seems that my Zabbix table was the only one that uses InnoDB!
                  • bernard
                    • Oct 2008
                    • 54
                    Disabled InnoDB log file size
                    The answer is quite late but I hop it could help someone else.
                    I disabled "innodb_log_file_size" from /etc/my.cnf and restart mySQL.
                    #innodb_log_file_size = 64M
                    I cannot explain why. I got this settings on my old Zabbix server, but it doesn't work anymore on my new installation. Is it Zabbix or mySQL issue
