Issue with Template in zabbix
  • VinodJunghare
    • Sep 2014
    I am zabbix newbie and using zabbix 2.0.8 and recently I have started facing an issue where in I am unable to add new hosts in zabbix , I get below error when i try to add new host with the template I have made.
    Have attached the screen shot for the same, removed my IP/hostname details in screen shot
    Error :
    Template cannot be linked to another template more than once even through other templates.
  • VinodJunghare
    • Sep 2014
    Hi Experts,
    Your experience would be very useful, please suggest something here .. tried almost every google sloution still no luck .
    • coreychristian
      • Jun 2012
      • 159
      It seems like the template maybe trying to link to the host twice. Could you provide a screen shot of the template tab for that host? Also can you add the hosts with no templates?
      • VinodJunghare
        • Sep 2014
        Hi Christian,
        Thanks for your response,
        Yes I am able to add host without linking to any templates.
        The issue is only when I try to link the template I have in place with me .
        I have also made sure I delete the host correctly from zabbix front end and add again, even the issue is observed for the host which is new to zabbix.
        I am unable to understand the culprit is template or data in database. I had intially used this template to assign to new and it worked, though I had a copule of hosts added and created custom graphs after which i think the issue started , I tried deleting all the custom graphs i created still fails.
        Attaching the snapshot of the template tab as requested.
        • ermanue
          • Sep 2015
          I have the same proble with 2.4.6.
          I don“t know what to do.
          I feel really frustrated-
