Hi there, i've tried everything i think.
I want individual entries to map each core of the servers performance.
I've tried perf_counter[\Processor Information(0,0)\% Processor Time]
perf_counter[\Processor(0)\% Processor Time]
and some others but no data comes in.
On my machine though they obviously are returning values...
Please help
7320:20140912:221238.765 Starting Zabbix Agent [GT-105-213]. Zabbix 2.2.5 (revision 47406).
7320:20140912:221238.765 using configuration file: C:\zabbix_agentd.conf
1388:20140912:221238.770 agent #0 started [collector]
4456:20140912:221238.770 agent #1 started[listener #1]
7016:20140912:221238.771 agent #2 started[listener #2]
6828:20140912:221238.771 agent #3 started[listener #3]
7496:20140912:221238.772 agent #4 started [active checks #1]
7496:20140912:221259.774 active check configuration update from [192.168.105.53:10051] started to fail (cannot connect to [[192.168.105.53]:10051]: [0x0000274C] A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.)
5104:20140915:084929.259 Zabbix Agent shutdown requested
1388:20140915:084929.317 zabbix_agentd collector stopped
4456:20140915:084929.447 zabbix_agentd listener stopped
5104:20140915:084930.259 Zabbix Agent stopped. Zabbix 2.2.5 (revision 47406).
8108:20140915:084931.707 Starting Zabbix Agent [GT-105-213]. Zabbix 2.2.5 (revision 47406).
8108:20140915:084931.708 using configuration file: C:\zabbix_agentd.conf
6688:20140915:084931.712 agent #0 started [collector]
4168:20140915:084931.713 agent #1 started[listener #1]
2800:20140915:084931.713 agent #3 started[listener #3]
6116:20140915:084931.714 agent #4 started [active checks #1]
3532:20140915:084931.714 agent #2 started[listener #2]
6116:20140915:084952.713 active check configuration update from [192.168.105.53:10051] started to fail (cannot connect to [[192.168.105.53]:10051]: [0x0000274C] A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.)
Please help
