Zabbix server not installed at FreeBSD 6.0
  • benzopila
    • Aug 2006
    Hello!
    Sorry for my poor english.
    I try to install zabbix server at FBSD 6.0 in these steps
    (by this manual: http://www.zabbix.com/manual/v1.1/install_server.php)
    1.create zabbix user, gave him permissions. Put src at home /usr.local/zabbix
    2.add mysql tables
    3.run ./configure --enable-server --with-mysql --with-net-snmp
    4.run make install (or make & make install - there is no difference at issue)
    it's quikly finished( very quily )
    And at the end there are
    -r--r--r-- 1 root wheel 1124 Aug 21 09:30 zabbix_agent.conf.sample
    -r--r--r-- 1 root wheel 1939 Aug 21 09:30 zabbix_agentd.conf.sample
    -r--r--r-- 1 root wheel 1801 Aug 21 09:30 zabbix_suckerd.conf.sample
    -r--r--r-- 1 root wheel 763 Aug 21 09:30 zabbix_trapper.conf.sample
    -r--r--r-- 1 root wheel 1179 Aug 21 09:30 zabbix_trapperd.conf.sample
    at /etc/zabbix, so where is zabbix_server?
    and there are only zabbix_agent and zabbix_suckerd script files at /usr/local/etc/rc.d.
    Where is server scripts and configs?
    And these files at /usr/local/bin :
    -r-xr-xr-x 1 root wheel 37804 Aug 21 09:30 zabbix_agent*
    -r-xr-xr-x 1 root wheel 50112 Aug 21 09:30 zabbix_agentd*
    -rwxr-xr-x 1 root wheel 18351 Aug 21 07:10 zabbix_get*
    -r-xr-xr-x 1 root wheel 9864 Aug 21 09:30 zabbix_sender*
    -r-xr-xr-x 1 root wheel 98320 Aug 21 09:30 zabbix_suckerd*
    -r-xr-xr-x 1 root wheel 48820 Aug 21 09:30 zabbix_trapper*
    -r-xr-xr-x 1 root wheel 53628 Aug 21 09:30 zabbix_trapperd*
    Where is server?
    I've configured zabbeix with --enable-server option.
    Why I have this result?
    Thanks for any help.
  • Fábio Emilio Costa
    • Aug 2006
    • 14
    It will depends on which type of monitoring you will use:
    In Listen Mode (monitoring by traps), server is 'zabbix_trapperd'
    In Polling Mode (monitoring by data retrieving), server is 'zabbix_suckerd'
    Anyway, before you believe that's bad, that's not: ZABBIX manual explain that you can use simultaneously Listen and Polling Modes.
