Zabbix Server stopped
  • phenriquer
    • Nov 2019
    I am upgrading zabbix from version 3.0 to 4.2, the tables were partitioned, I removed using 'alter table remove partitioning table_name'.
    I'm using mysql Ver 14.14 Distrib 5.7.17 and Red Hat Enterprise Linux Server release 6.10 (Santiago)
    This is the result of the command 'tail -20 /var/log/zabbix/zabbix_server.log'
    37009:20191123:155344.882 End of DBflush_trends()
    37009:20191123:155344.882 In DBflush_trends() trends_num:2
    37009:20191123:155344.882 query [txnlev:1] [select distinct itemid from trends_uint where clock>=1574532000 and itemid in (23662,28534)]
    37009:20191123:155344.883 query [txnlev:1] [insert into trends_uint (itemid,clock,num,value_min,value_avg,value_max) values (23662,1574532000,1,0,0,0),(28534,1574532000,1,0,0 ,0);
    37009:20191123:155344.883 End of DBflush_trends()
    37009:20191123:155344.883 query [txnlev:1] [commit;]
    37009:20191123:155344.894 syncing trend data done
    37009:20191123:155344.894 End of DCsync_trends()
    37009:20191123:155344.894 End of DCsync_all()
    37009:20191123:155344.894 End of free_database_cache()
    37009:20191123:155344.894 In free_configuration_cache()
    37009:20191123:155344.894 End of free_configuration_cache()
    37009:20191123:155344.894 In zbx_vc_destroy()
    37009:20191123:155344.894 End of zbx_vc_destroy()
    37009:20191123:155344.894 In free_selfmon_collector() collector:0x7fb914326000
    37009:20191123:155344.894 End of free_selfmon_collector()
    37009:20191123:155344.894 In zbx_unload_modules()
    37009:20191123:155344.894 End of zbx_unload_modules()
    37009:20191123:155344.894 Zabbix Server stopped. Zabbix 4.2.6 (revision d3bb18bbc4).
    Anyone can help me ?
  • Kachou
    • Feb 2020
    • 10
    I have exactly the same problem.
    Is there anyone who would have found a solution to our problem?
    Thanks in advance for your help,
    Kachou
    • Kachou
      • Feb 2020
      • 10
      I found the solution is to just reinstall the zabbix server, because it no longer existed in / usr / sbin
      So it was impossible to launch it.
      I hope this will help you too,
      Kachou
