Getting working the Slack Bot
  • Gadg3ts
    • Jan 2020
    • 11
    I've been trying to get Slack notifications from Zabbix working by a couple of methods, with varying success.
    1) Zabbix Notify - https://github.com/v-zhuravlev/zabbix-notify
    This I had all set up as per the instructions, and I can get it to send a test notification into the alerts channel. However, it wouldn't send anything automatically.
    2) The official "Slack Webhook" - https://www.zabbix.com/integrations/slack
    (after renaming the previous 'Slack' media type from option #1) I managed to get this set up as far as possible according to the instructions.
    However, they're a bit out of date - adding a 'bot user' doesn't exist any longer as described, instead, that stage in the process asks you what API scopes you want to give your bot, which if you've not tried to do this with Slack before, is going to be a bit of a lucky dip.
    Having previously spent some time shouting at Slack when writing a script to automate the inviting of users, I'ver added "chat:write" to both the bot and user scopes as it seemed like the most relevant, but I'm not 100% sure if that's what is required in this case...
    Does anyone know / can point me to what I need to get this working as it should be? or where in Zabbix to find what it's actually sending as the webhook content?..
    Thanks,
    Sean
  • jochristian
    • Jan 2020
    Hi Gadg3ts,
    Did you find an solution to the official slack webhook solution.
    So far now luck in my installation. When doing an test I only get this response back.
        "tags": {}
    /Jo Christian
    • CPerson
      • Mar 2020
      I went through the same issue yesterday as I migrated from the zbx-notify script I had been using for several years. After some testing I found these OAuth scopes to work for me.
      • chat:write
      • chat:write.customize
      • chat:write.public
Name:	Screenshot from 2020-03-13 07-14-40.png
      • andre_tux
        • Mar 2021
        I am also struggeling to get the Clag notification working. When I test, I also just get the empty tag back, like jochristian.
        I tried the scopes settings that CPerson suggested, but nothing.
        I am using Zabbix 4.4
        Any other ideas to try?
        Andre
        • krenaud
          • Feb 2019
          I am using Zabbix 5.2 and the built in webhook integration. Problems appear in Slack (sent three times), but not resolved items.
          If I look at details for the Event the Problem that has been sent to Slack I get "Slack notification failed : invalid_auth" for the problem (even though it obviously did reach slack all three attempts).
          For the resolved event that does not reach Slack I get "Slack notification failed: channel_not_found".
          Are there any logs or something that can be used for troubleshooting?
          • mwildam
            • Feb 2021
            • 72
            I have the same problem, but anyway, in my case the messages arrive in slack. Did you invite the bot to the channel? BTW: In my case it does not make any difference, if I write the # in front of the channel name or not.
            • mwildam
              • Feb 2021
              • 72
              You could try it "by hand" - as Sean does it in this video: https://youtu.be/zZSXEvjpfbY
              • mwildam
                • Feb 2021
                • 72
                I found a newer, more recent video of Sean again showing the newer Slack integration: https://youtu.be/3-ONmc43vMw - I will watch this, if it shows anything new.
                • Zwirni
                  • Sep 2019
                  Got the same error in a Zabbix 5.2. I think there might be a bug in the script here:
                  https://git.zabbix.com/projects/ZBX/...Frelease%2F5.2
                  In the script for 5.4 there are some fixes that might be solve it. But I could not figure it out until now.
                  • pc99096
                    • Oct 2011
                    • 193
                    it seems that if you replace the "event_update_status" variable with "1" (instead of {EVENT.UPDATE.STATUS}), it does not fail
                    • Zwirni
                      • Sep 2019
                      This fixed the three-time problem-message in Slack - but I never get an OK-message. There is the error "channel_not_found" visible.
                      • mwildam
                        • Feb 2021
                        • 72
                        You are my hero - that did the trick! Thanks a lot!
                        • kisarakana
                          • Mar 2021
                          Hello.
                          I'm also using slack notifications in Zabbix 5.0 and I was able to post to slack but was getting an invalid_auth error.
                          The token is embedded by Get processing with the function getPermalink in the script, but the invalid_auth error disappeared when I modified it as follows.
                          function getPermalink(channelId, messageTimestamp) {
                             var req = new CurlHttpRequest();
                             req.AddHeader('Content-Type: application/x-www-form-urlencoded; charset=utf-8');
                             req.AddHeader('Authorization: Bearer ' + params.bot_token);
                             var resp = JSON.parse(req.Get(
                                '{0}?channel={1}&message_ts={2}'.format(
                                   Slack.getPermalink,
                                   channelId,
                                   messageTimestamp
                             if (req.Status != 200 && !resp.ok) {
                                throw resp.error;
                             return resp.permalink;
                          • mwildam
                            • Feb 2021
                            • 72
                            What the hack... - It worked for a few messages and then refused again. - Channel not found it says.
                            • mwildam
                              • Feb 2021
                              • 72
                              #15
                              I tried to apply the changes mentioned here:
                              It looks like it's only working for problem messages and not for recovery messages.
