Duplicate host names on different proxies
  • mellis
    • Oct 2017
    • 145
    I have run into an issue with a large system I am building out. It seems that sometime in the past my company managed to create two domains with the same domain name and going by a standard host naming convention we being dumb as a rock now have at least four hosts with the same name. This is not a problem because the domains d not touch. But now they want to have Zabbix monitoring using proxies. My question is will this be a problem or not?
  • LenR
    • Sep 2009
    • 1011
    The hostname to Zabbix is whatever you put in zabbix-agentd.conf Hostame, so you can assign a unique host name to each.
    • mellis
      • Oct 2017
      • 145
      We normally use the hostnameitem=system.hostname, In our system I will not have access to these systems. I am not sure hand editing each of the agent config files is a viable solution for our deployment
