LLD macros in zabbix 4.4.5
  • AVZ
    • Feb 2020
    Hello!
    According to the documentation https://www.zabbix.com/documentation...evel_discovery:
    "Note that since Zabbix 4.2, the format of the JSON returned by low-level discovery rules has been changed. It is no longer expected that the JSON will contain the "data" object. Low-level discovery will now accept a normal JSON containing an array, in order to support new features such as the item value preprocessing and custom paths to low-level discovery macro values in a JSON document."
    I have zabbix 4.4.5. I get the following JSON in the discovery rule using the http agent:
                "@attributes": {
                    "version": "1.0"
                "hdd": [
                        "@attributes": {
                            "version": "1.0"
                        "id": "1",
                        "hddName": "hdda",
                        "hddPath": {},
                        "hddType": "SATA",
                        "status": "ok",
                        "capacity": "5723166",
                        "freeSpace": "0",
                        "property": "RW"
                        "@attributes": {
                            "version": "1.0"
                        "id": "2",
                        "hddName": "hddb",
                        "hddPath": {},
                        "hddType": "SATA",
                        "status": "ok",
                        "freeSpace": "0",
                        "property": "RW"
    In LLD macros, I specify:
    {#TEST} $..id
    Checking the path to the node in JSONPath I get the result: ["1", "2"].
    But the discovery rule does not work due to an error: "Cannot find the "data" array in the received JSON object.".
    Why doesn't LLD work with json without a "data" object?
    If I add the "data" object to json, then LLD starts working:
        "data": [
                "@attributes": {
                    "version": "1.0"
                "hdd": [
                        "@attributes": {
                            "version": "1.0"
                        "id": "1",
                        "hddName": "hdda",
                        "hddPath": {},
                        "hddType": "SATA",
                        "status": "ok",
                        "freeSpace": "0",
                        "property": "RW"
                        "@attributes": {
                            "version": "1.0"
                        "id": "2",
                        "hddName": "hddb",
                        "hddPath": {},
                        "hddType": "SATA",
                        "status": "ok",
                        "freeSpace": "0",
                        "property": "RW"
    Checking the path to the node $..id in JSONPath I get the same result: ["1", "2"], but only one element of the following form is created from the prototype:
    Имя Триггеры Ключ
    Hik_hdd_lld: SMART_hdd_["1","2"] HIK_SMART_HDD["["1","2"]"]
    Why do values ​​have this form and why was 1 value created, not 2?
  • vso
    Zabbix developer
    • Aug 2016
    • 190
    Because it need array, for example the following should work:
        "@attributes": {
            "version": "1.0"
        "id": "1",
        "hddName": "hdda",
        "hddPath": {},
        "hddType": "SATA",
        "status": "ok",
        "freeSpace": "0",
        "property": "RW"
        "@attributes": {
            "version": "1.0"
        "id": "2",
        "hddName": "hddb",
        "hddPath": {},
        "hddType": "SATA",
        "status": "ok",
        "freeSpace": "0",
        "property": "RW"
    • AVZ
      • Feb 2020
      Indeed, this is how LLD works. But why are values ​​inserted in quotation marks and in square brackets?
      This is a prototype:
      and this is an item:
      • AVZ
        • Feb 2020
        To get only the value, you can use {{#LLDMACRO} .regsub (pattern, output)} as a workaround.
        • rhysjonas
          • Feb 2020
          Try using {{#LLDMACRO} .regsub (pattern, output)} as a workaround.
          spanish dictionary
