how do I disable LDAP Auth without GUI access
  • tjyang
    • Jun 2016
    • 11
    My ldap auth configuration stop working(due to bind account password expiration ? ).
    failed to connect to LDAP server
    In R1, we can reset the local Admin password using sql statement.
    But I need to disable LDAP Auth configuration to go back to R1 case.
    Is there sql statements to disable ldap auth ?
    R1: https://www.zabbix.com/forum/zabbix-...out-gui-access
    R2: Zabbix server 4.4.5 using timescaledb.
  • tim.mooney
    • Dec 2012
    • 1436
    There are a bunch of LDAP-related columns in the 'config' table of the Zabbix database. There's also the "authentication_type" column, which probably has different integer values depending on which authentication type has been configured.
    • sancho
      • Mar 2015
      • 301
      Hi tjyang
      Look at this post: https://www.zabbix.com/forum/zabbix-...760#post244760
