[Zabbix server] Some hosts no more trigger Problems
  • Frogg
    • Mar 2020
    • 18
    I have searched on the forum and internet, and didn't find anything about it, so i post here my problem
    Version:
    I am using the appliance iso 4.4.4 i updated it to 4.4.6 to try to solve the problem without success.
    Trouble:
    I already re-installed 2 times Zabbix with the same trouble. After reinstalling all is working well, then after around 1 month the problems aren't refreshing in the web interface for some host.
    - lastest data are up to date
    - Queue is empty
    It is like triggers are not triggering for some hosts.
    I cant find logs with error
    serverlog (today after updating to 4.4.6 but no error was sent in previous version too):
     16349:20200309:113446.023 Zabbix Server stopped. Zabbix 4.4.5 (revision b93f5c4fc0).
      4909:20200309:113446.070 Starting Zabbix Server. Zabbix 4.4.6 (revision 8cc702429d).
      4909:20200309:113446.071 ****** Enabled features ******
      4909:20200309:113446.071 SNMP monitoring:           YES
      4909:20200309:113446.071 IPMI monitoring:           YES
      4909:20200309:113446.071 Web monitoring:            YES
      4909:20200309:113446.071 VMware monitoring:         YES
      4909:20200309:113446.071 SMTP authentication:       YES
      4909:20200309:113446.071 ODBC:                      YES
      4909:20200309:113446.071 SSH support:               YES
      4909:20200309:113446.071 IPv6 support:              YES
      4909:20200309:113446.071 TLS support:               YES
      4909:20200309:113446.071 ******************************
      4909:20200309:113446.071 using configuration file: /etc/zabbix/zabbix_server.conf
      4909:20200309:113446.092 current database version (mandatory/optional): 04040000/04040001
      4909:20200309:113446.092 required mandatory version: 04040000
      4909:20200309:113446.141 server #0 started [main process]
      4910:20200309:113446.142 server #1 started [configuration syncer #1]
      4916:20200309:113446.250 server #7 started [history syncer #2]
      4915:20200309:113446.250 server #6 started [history syncer #1]
      4914:20200309:113446.251 server #5 started [discoverer #1]
      4917:20200309:113446.251 server #8 started [history syncer #3]
      4918:20200309:113446.251 server #9 started [history syncer #4]
      4913:20200309:113446.252 server #4 started [http poller #1]
      4919:20200309:113446.254 server #10 started [escalator #1]
      4912:20200309:113446.254 server #3 started [timer #1]
      4920:20200309:113446.256 server #11 started [java poller #1]
      4921:20200309:113446.257 server #12 started [java poller #2]
      4922:20200309:113446.258 server #13 started [java poller #3]
      4911:20200309:113446.262 server #2 started [housekeeper #1]
      4923:20200309:113446.262 server #14 started [java poller #4]
      4924:20200309:113446.266 server #15 started [java poller #5]
      4925:20200309:113446.269 server #16 started [snmp trapper #1]
      4926:20200309:113446.272 server #17 started [proxy poller #1]
      4935:20200309:113446.281 server #19 started [task manager #1]
      4934:20200309:113446.282 server #18 started [self-monitoring #1]
      4936:20200309:113446.283 server #20 started [poller #1]
      4937:20200309:113446.284 server #21 started [poller #2]
      4938:20200309:113446.287 server #22 started [poller #3]
      4940:20200309:113446.290 server #23 started [poller #4]
      4941:20200309:113446.298 server #24 started [poller #5]
      4942:20200309:113446.300 server #25 started [unreachable poller #1]
      4944:20200309:113446.302 server #27 started [trapper #2]
      4943:20200309:113446.304 server #26 started [trapper #1]
      4945:20200309:113446.307 server #28 started [trapper #3]
      4946:20200309:113446.311 server #29 started [trapper #4]
      4951:20200309:113446.324 server #30 started [trapper #5]
      4952:20200309:113446.326 server #31 started [icmp pinger #1]
      4953:20200309:113446.328 server #32 started [alert manager #1]
      4954:20200309:113446.332 server #33 started [alerter #1]
      4955:20200309:113446.334 server #34 started [alerter #2]
      4957:20200309:113446.338 server #35 started [alerter #3]
      4958:20200309:113446.341 server #36 started [preprocessing manager #1]
      4962:20200309:113446.353 server #40 started [lld manager #1]
      4963:20200309:113446.354 server #41 started [lld worker #1]
      4964:20200309:113446.355 server #42 started [lld worker #2]
      4965:20200309:113446.356 server #43 started [alert syncer #1]
      4959:20200309:113447.045 server #37 started [preprocessing worker #1]
      4960:20200309:113447.047 server #38 started [preprocessing worker #2]
      4961:20200309:113447.050 server #39 started [preprocessing worker #3]
    zabbix agent log
     22559:20200309:113426.355 Zabbix Agent stopped. Zabbix 4.4.5 (revision b93f5c4fc0).
      4794:20200309:113431.363 Starting Zabbix Agent [zabbix.server.home]. Zabbix 4.4.6 (revision 8cc702429d).
      4794:20200309:113431.363 **** Enabled features ****
      4794:20200309:113431.363 IPv6 support:          YES
      4794:20200309:113431.363 TLS support:           YES
      4794:20200309:113431.363 **************************
      4794:20200309:113431.363 using configuration file: /etc/zabbix/zabbix_agentd.conf
      4794:20200309:113431.363 agent #0 started [main process]
      4796:20200309:113431.364 agent #2 started[listener #1]
      4797:20200309:113431.365 agent #3 started[listener #2]
      4795:20200309:113431.365 agent #1 started [collector]
      4798:20200309:113431.365 agent #4 started[listener #3]
      4799:20200309:113431.374 agent #5 started [active checks #1]
    Zabbix server Configuration is default from appliance iso
    Anyone know how i can track the trouble or find a solution (without reinstalling another time) ?
    Thanks.
  • Frogg
    • Mar 2020
    • 18
    I think i found, i leveled up log to 4 and i saw some error due to script on zabbix share with error in it...
