Hosts are showing zabbix server data not agent data
  • cgrafner
    • Mar 2020
    I was using version 4 of zabbix on ubuntu 16.04 server and it was working great with my agents. I had a power outage and it corrupted my database. I could not get it fixed so I started over with ubuntu 18.04 server and zabbix 4.4. Install went well, agent is installed on a Windows server just like before. I setup the host with the correct name and linked a template. The problem is that I see data for that host but it is the zabbix server data and not the agent data from that server. Not sure what I am missing.
    Probably something simple.
  • sigafoos
    • Apr 2020
    • 10
    I could be wrong, but it sounds like you are using the Zabbix server IP address instead of the host address...could be wrong.
    • cgrafner
      cgrafner commented
      On the server or the agent? The agent is using the server address. I am not having the server pull data from the agents, just the agent push to the server.
  • cgrafner
    • Mar 2020
    So I was able to figure this out. It was an error on my part with configuring the agent.
    • jmbwell
      • Jan 2022
      What was the configuration error? I am having this issue with Zabbix agent 5.4 on pfSense systems. All of the inventory data is coming from the server instead of from the agent.
      • jmbwell
        • Jan 2022
        In my case, setting listen IP to a specific IP address reachable by the Zabbix server (instead of the default 0.0.0.0) cleared things up. Hope this helps!
