Web scenario trigger with required string
  • lpossamai
    • Jun 2018
    • 119
    I have a couple of web scenarios, and some of them have "Required String" enabled. The endpoint will always return http response code 200, even if the required string doesn't match. Example:
    Step 1
    Endpoint: https://api.example.com/api/v1/status
    Required string: "ApiStatus" status="up"
    Step 2
    Required string: "Apiv2Status" status="down"
    The status code of https://api.example.com/api/v1/status will always be 200, even if it shows "Apiv2Status" status="down", so I cannot use the web.test.rspcode function.
    I wanna create a trigger that, if a certain step have status="down", trigger an alarm.
    How can I achieve that?
  • lpossamai
    • Jun 2018
    • 119
    According to Web monitoring:
    The following information is collected in any web scenario step:
    • download speed per second
    • response time
    • response code
    so that means that I need to create different Web Scenarios for each one of the "steps'. Am I right?
    • tim.mooney
      • Dec 2012
      • 1434
      Will the "Required string" field for Zabbix Web scenarios work if you invert the test and require that status="up" be present for the step to be OK?
      • lpossamai
        • Jun 2018
        • 119
        Yes... that could work... so If status is != status="up", triggers an alarm.
