error "Cannot send request: wrong item type." when i press Check now button for item
  • awrow
    • May 2020
    • 16
    hello,
    with zabbix server 4.2.5 i try to make an item with this parameters:
    i want to get a log from one of my zabbix-agents.
    when i press the Check now button on an item tab i get an error message Cannot send request: wrong item type.
    what am i doing wrong?
  • awrow
    • May 2020
    • 16
    upd: I was wrong. Error is stil here.
    The reason was I've set the wrong Hostname parameter in the /etc/zabbix/zabbix_agentd.conf. The value should be the host name of a "host" in terms of Zabbix.
    upd2: But the item seems to work.....
    • ivgenyr
      • Jun 2020
      • 17
      I have the same problem, and in my case the item is working ...
      • Hamardaban
        • May 2019
        • 2714
        https://www.zabbix.com/documentation.../hosts/items?s[]=check&s[]=now
        • Check now - execute a check for new item values immediately. Supported for passive checks only (see more details).
        • awrow
          • May 2020
          • 16
          if it's working then what's the problem?
          • Hamardaban
            Hamardaban commented
            Did I understand correctly that the data element is working, but the "check now" button is not working? If Yes, then you are offered a version of why this is happening. You can find more details in the documentation. If not, just ignore what I wrote.
          • awrow
            awrow commented
            I somehow managed this. Unfortunately I don’t remember how
          • awrow
            awrow commented
            I’ve been asking ivgenyr for any details
        • ivgenyr
          • Jun 2020
          • 17
          Hamardaban you comment was correct, it doesn't worl for active checks. Thank you!
