External Script
  • aniltonf
    • Dec 2014
    External Script
    Hello...
    I have an script (shell Script) that read from a Data Base values that I'll like to show in a chart in ZABBIX.
    Solution:
    I have an script reading from an equipmente all errors avery 5min and store the info into a DB.
    Than, I have this script picking tha data from DB and show on the screan.
    Question:
    1. What paramenters is ZABBIX wating...
    2. How can I set this script into zabbix and configure a chart with it...
    I've searching a lot into severals docs but, nothing is about my problem.
    If someone can help, please
    Thank you
  • BDiE8VNy
    • Apr 2010
    • 680
    There are several ways thinkable:
    • External checks - to execute a script/command to evaluate a value per item or to send a bulk of item values to proper Trapper items.
    • Trapper items - to send data either individually or in a bulk by a script/program.
    • User parameters - see External checks
    • Loadable modules see User parameters/External checks
    • ODBC monitoring - to query item values from a database directly
    Once the values are gathered one can visualize them in Graphs
