Zabbix MySQL Configuration Issue - create.sql.gz failing
  • MattCrum
    • Jun 2020
    I'm following the instructions here to install Zabbix fresh on Centos7 with MySQL and it's failing at the d. Create initial database step.
    Zabbix is being downloaded over 4 000 000 times every year for a reason. Download and install Zabbix for free and try it yourself!
    I can create the table fine, but running this command results in an error:
    zcat /usr/share/doc/zabbix-server-mysql*/create.sql.gz | mysql -uzabbix -p zabbix
    Enter password:
    ERROR 1071 (42000) at line 348: Specified key was too long; max key length is 767 bytes
    I've researched this and it appears to be an issue with UTF8 limits - a forum post suggested doing this:
    SET @@global.innodb_large_prefix = 1;
    This got a bit further, but now we're presented with the following error instead:
    ERROR 1709 (HY000) at line 348: Index column size too large. The maximum column size is 767 bytes.
    Rather than mess around with it any more, I thought it would be best to raise the issue here - any thoughts on how to get this fixed?
    MYSQL: mysql  Ver 14.14 Distrib 5.6.48, for Linux (x86_64) using  EditLine wrapper
    CENTOS: Linux version 3.10.0-1127.8.2.el7.x86_64 ([email protected]) (gcc version 4.8.5 20150623 (Red Hat 4.8.5-39) (GCC) ) #1 SMP Tue May 12 16:57:42 UTC 2020
  • tim.mooney
    • Dec 2012
    • 1434
    You may want to report this on the Zabbix bug tracker (support.zabbix.com) and be clear that this is for a fresh install.
    Others on the forums have run into the same issue, with various versions of MariaDB and MySQL.
    Based on the research I've done for MariaDB, I think that innodb_large_prefix may not be enough, if your installation is defaulting to row_format = COMPACT.
    If you connect to your mysql server and do
    SHOW TABLE STATUS FROM zabbix;
    what does the Row_format say for your columns?
    • MattCrum
      • Jun 2020
      Thanks for the response tim.mooney - I ended up getting it working with a more recent version of MariaDB vs a MySQL package; it looks lke there are numerous issues with using MySQL versions prior to 5.7 (before the limits were increased).
      I installed the default version of MariaDB using yum and everything worked fine:
      yum install mariadb
      mysql Ver 15.1 Distrib 10.4.13-MariaDB, for Linux (x86_64) using readline 5.1
