Issue with Agent on Windows
  • sunil.kalra
    • Dec 2014
    I have installed the agent on windows 2008 & 2012 r2 but I am having an issue where the service installs OK but doesnt start. I get the message that it didnt start in a timely fashion.
    The config file has been edited. I have basically commented out the passive checks and set ServerActive.
    the service properties has the path pointing to zabbix_agentd and the conf file.
    Any help is appreciated.
  • OriginNG
    • Dec 2014
    • 15
    Try to start the agent from a cmd.exe prompt. You can find the command used if you look at the zabbix services throught the services controlpanel item.
    Joop
    • sunil.kalra
      • Dec 2014
      Thanks,
      I had already tried that method.
      The issue is resolved now but I don't know why.
      I defined the attribute "Server" under passive in the conf and that made it start though it is in active mode because I have "ServerActive" defined.
      • Jason
        • Nov 2007
        • 431
        You need to have startagents=0 to disable the passive agents from starting if you're only using active agents.
