First things first
  • stercor
    • Jan 2015
    First things first
    Zabbix 2.4.3, Manjaro 0.8.11, Linux 3.18
    How do I get to the first screen?
    I tried
    Result: "This webpage is not available"
    localhost:10000 didn't work either.
    /sbin/zabbix from the command line didn't work.
  • tchjts1
    • May 2008
    • 1605
    If the correct frontend install steps were followed, then it would be this:
    Installing frontend
    Step 1
    In your browser, open Zabbix URL: http://<server_ip_or_name>/zabbix
    (located here: https://www.zabbix.com/documentation...lation/install)
    If you did install correctly, then my guess would be that permissions are not set correctly for your HTML files, or Apache is not running. I have done upgrades in the past and forgot to re-set permissions after I copied a new frontend in place. That was the error that I would get.
    • aib
      • Jan 2014
      • 1615
      In addition to permissions check - please, check all Firewall or SElinux, that they configured properly.
      Sincerely yours,
      Aleksey
