No Such Instance currently Exists at this OID
  • quebrantos
    • Jul 2020
    I'm creating a template to monitor a couple of FC Switchs
    With snmpwalk I get this answer
    snmpwalk -v 2c -c comm 10.19.32.210 .1.3.6.1.3.94.1.6.1.6
    SNMPv2-SMI::experimental.94.1.6.1.6.16.0.0.192.221.13.114 .22.0.0.0.0.0.0.0.0 = INTEGER: 3
    snmpwalk -v 2c -c comm 10.19.32.209 .1.3.6.1.3.94.1.6.1.6
    SNMPv2-SMI::experimental.94.1.6.1.6.16.0.0.192.221.36.155 .118.0.0.0.0.0.0.0.0 = INTEGER: 3
    When I create the item with OID .1.3.6.1.3.94.1.6.1.6 Zabbix give me No Such Instance currently Exists at this OID
    What would be the correct OID to put on the template?
    Thank you.
  • Hamardaban
    • May 2019
    • 2713
    Because there is nothing on this oid! Try requesting snmpget instead of snmpwalk.
    There is a .1.3.6.1.3.94.1.6.1.6.16.0.0.192.221.13.114.22.0.0 .0.0.0.0.0.0.
    Maybe this will help https://www.zabbix.com/documentation...p/dynamicindex
    • quebrantos
      • Jul 2020
      Got it!
      I Created a discovery rule to retrieve the index and query the value whit a prototype
      Thank you!
      • Rohitmahajan701
        • Apr 2023
        quebrantos
        I am getting the same issue as you were getting/ Could you please help me in solving this issue like you did by creating a discovery rule to retrieve the index and query the value with a prototype ? How to do this
        • quebrantos
          • Jul 2020
          Take a look at this template. I needed to check the status of the switch ports, so I made the "Status Discovery" Discovery Rule with item an trigger prototypes. This way during the discovery process the correct SNMP indexes are found.
          • Rohitmahajan701
            • Apr 2023
            quebrantos THank you so much for the reply. I need to get CPU utilization for Oracle device .. Do you have such template for CPU utilisation ?
